Drag link question, 1956 F100 - Ford Truck Enthusiasts Forums
Old 12-27-2013, 07:34 PM
seawulff seawulff is offline
seawulff is starting off with a positive reputation.
My steering has always been rough, kind of sticks and binds. I bought a spring scale and adjusted the steering as per the manual and with the pitman arm loose it is smooth and appears appropriate. I disconnected the drag link and when I took the end off there is no spring or other pieces in there just the two pieces that surround the ball on the pitman arm. Is this correct? The manual shows a spring, and spring guide plus the other parts. Is this the reason it is rough? Thanks.
Old 12-27-2013, 08:45 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
I would suspect the steering could be quite rough, sticky without the ***** being under spring pressure and the cushion and flexibility the springs provide. Check the ***** for being round, replace if worn. Order and install a rebuild kit correctly.
Old 12-27-2013, 11:29 PM
artford54 artford54 is offline
artford54 is starting off with a positive reputation.
What's the best way to change the ball stud? Take the arm off? Help!
Old 12-28-2013, 12:55 AM
Thanks, already ordered!
Old 12-28-2013, 01:39 AM
jimcar-9 jimcar-9 is offline
jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.
The worm gear in the box is also know to chip and give some strange feelings.
Old 12-28-2013, 03:11 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
A8TZ-3A533-A .. Draglink Ball Stud Repair Kit-1948/52 F1/F2/F3 / 1953/56 F100/250.
Note in pic that basic numbers with black dot are included in kit.
Left upper picture:
Old 12-28-2013, 11:54 PM
Sorry for getting my nose in there. Ignore my question.
Pitman arm question -79 F250 4x4 Corn Fed 1973 - 1979 F-100 & Larger F-Series Trucks 24 11-09-2013 08:49 AM
Which Pitman arm to use? DoubleBypass 1967 - 1972 F-100 & Larger F-Series Trucks 0 04-11-2013 10:35 AM
Pitman arm steering box install????? flamesoldier 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 02-11-2013 11:04 PM
Toyota MANUAL Steering Box Pitman Arm Issue okedokeno 1948 - 1956 F1, F100 & Larger F-Series Trucks 28 10-26-2012 11:45 PM
1961 F-100 pitman arm 61UniB100 1961 - 1966 F-100 & Larger F-Series Trucks 2 09-16-2009 10:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
