1990 e350 ambulance transmission help
Hi all,
I have a 1990 ford e350 ambulance with 7.3 diesel and with automatic tranny with overdrive.
it is shifting fine, but on the highway it seems this has a lockup converter or something which is unlocking and locking at weird times on the highway cruising in overdrive. how is this controlled so i can fix it. thanks.
mark
mark
Ok I will check my brake light switch, and when the other person says "the computer controls it", . what does the computer control it with? if vacuum, my vacuum pump is out and been using a electric brake vacuum booster, only to power my brakes, the rest of the vacuum system isnt working, and there seems to be a shift cable of some type that isnt hooked to anything near the injection pump. . thanks. i dont know what trans it is, but its the one with the overdrive off button on the dash if that helps.
mark
mark
Ok , so the brake light switch is the only thing beside the computer that controlls it? I explained I have cable lying near the injection pump that isnt hooked up, look like a throttle cable.. I had a 1986 buick grand national with a GM 200r4, that had a brake light switch, then relied on a throttle position sensor too , both would have effect on when the converter locks and unlocks. does this have anything connected to the gas peddle? thanks..
,mark
,mark
The computer controls the torque converter clutch, along with the rest of the transmission. The brake light switch is one of many inputs to the computer. So is the throttle position sensor, the trans range sensor, the vehicle speed sensor, etc.
You would be well advised to see if there are any codes stored in the computer.
Ok thank you, iam 100 percent positive something is misadjusted that controls it. its a reman tranny 30k ago . Iam just wondering, does the throttle position sensor need to be calibrated every so often?, also do you know where I can find out where things like where the speed sensor is grounded, and the ground for the computer. I want to check to make sure they are all nice and clean as Iam chasing down a small electrical problem already (if I hit a bump, a buzzer comes on and stays on under the dash,used by the rear paramedic to signal the driver, also i lose battery 1 and 2 indicators) but those are ambulance related. thanks for the help.
mark
mark
mark
mark
The cable sometimes gets left off when doing other repairs.
It wouldn't have any effect on your transmission problem, so don't worry about it now, that's another "project"
The cruise control uses a CABLE to activate the throttle... this is what I thought you might be speaking of..
Sorry I tried to help!!!!!!!!!!!!
HoustonDave
08-11-2016 09:18 AM
Nanook 1955
04-15-2016 02:01 PM
Mitch Eckler
20
04-08-2016 09:18 PM
