2010 XLT Reverse Gear & Parking Brake taps. Need help
First off this is my first post and wanted to say thank you in advance for the community and knowledge that is here. I have tried to search and I can not find the answer in which I need.
I am installing a Parrot Asteroid Smart into a 2010 XLT without sub or sync. I will also be hooking up a reverse camera. All wires are ran and the harness is built. I have two wires that I am having problems with to make everything function correctly.
Coming from the Parrot, I need to tap into the Reverse Gear and Park Brake. They are separate wires. Where can I tap into these wires? On the side of the shifter I do see three wires but I am not sure where they are going.
Again, thanks for the help.
In case anyone else has this problem. I ended up tapping into the #15 fuse. It is a 10a and it is under the parking brake. I used something like this to tap but for the mini fuse:
Cooper Bussmann/ATC fuse tap (BP-HHA-RP) | Fuse and Accessories | AutoZone.com
Hope this helps if anyone else runs into this situation.
SUPERDUTY_08
12-24-2011 10:44 PM
djpahan
04-10-2011 09:19 PM
MHowell
1978 - 1996 Big Bronco
12-27-2002 06:41 PM
