Battery cable sizes
Best guess the cables are likely 4 to maybe even as small as a 5 gauge. If you are doing cables I would do something along the lines of 2 or better. If you run a big alternator, a double 0 or zero is preferable for the charge line to the first (passenger side) battery. I don't have a gauge to measure mine but that's what I recall looking at wire locally. You might even want to run an extra ground strap from alternator to frame on passenger side, again, this one should be 00 or 1 gauge if a big alternator. Just my opinion, others will chime on here too.
78 & 87 Super Cab
05-20-2014 04:27 PM
snaponprofile
05-07-2011 08:43 PM
96-5spd302
06-11-2004 03:19 PM
