6.4 blowing white smoke... help please - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 12-26-2013, 02:12 PM
chesterstroker chesterstroker is offline
chesterstroker is starting off with a positive reputation.
We are on the way to Colorado pulling four place enclosed and my truck started running rough and blowing a lot of white smoke. I got it limped two miles to nearest truck stop. Minimaxx shows cylinder eight and cylinder one contribution codes. Oil level is good but coolant is low. The drivers side of engine looks wet but I can't tell for sure what it is. All vitals were normal up to this. Truck has dpf delete and mini maxx on it. Any ideas? Does this sound like a failing egr cooler?
Old 12-26-2013, 03:42 PM
RTRF350's Avatar
RTRF350 RTRF350 is offline
RTRF350 is starting off with a positive reputation.
Sounds like the egr cooler to me.
Old 12-26-2013, 04:20 PM
9228.bobcat's Avatar
9228.bobcat 9228.bobcat is offline
9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.
Is there coolant coming out of the degas bottle?
Old 12-26-2013, 04:43 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
EGR coolers. Don't drive it and risk a hydrolock.
Old 01-01-2014, 04:40 PM
Quote:
There isn't any coolant coming out of degas bottle. What is the easiest way to check for ruptured egr cooler? I have the delete kit at home already. Maybe I'll just install the delete and see how it runs...
Old 01-01-2014, 06:15 PM
parkland parkland is offline
parkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud of
Were you using a stock tune, or EGR disable tune?
Old 01-01-2014, 07:21 PM
Quote:
Running disable tune with minimaxx
Old 01-01-2014, 11:18 PM
tgreening's Avatar
tgreening tgreening is offline
tgreening has a good reputation on FTE.tgreening has a good reputation on FTE.
Quote:
How did you determine this? To me this sounds like a case of blown head gasket. Low coolant, wet engine bay, white smoke.
No matter what it is, there is obviously a problem, and I seriously doubt just adding the dpf delete is going to solve whatever is going on.
Old 01-05-2014, 08:02 PM
brian1253 brian1253 is offline
brian1253 is starting off with a positive reputation.
Compression test you don't loose compression through the erg cooler.
Old 01-11-2014, 08:33 PM
Ok guys, here's the update on my truck. I got it towed home and in my garage. Installed egr cooler delete just because I already had it and was going to do it anyway...did not fix my problem I checked compression on number eight and have zero. Pulled glowplug and looked through hole with borescope...piston cracked all the way across top. Truck still ran when I pulled it into garage but smelled very strong raw diesel out of exhaust. What do you suppose caused this to happen? Im guessing number eight injector stuck open. Im going to pull the motor and rebuild with head studs and all new pistons. Can these injectors be bench tested out of the truck. I don't want to worry about this happening again but I really don't want to replace all eight injectors if I don't have to. Sorry for the long winded post. I have rebuilt tons of gas engines but this will be my first diesel. I wanna do it right because I really love this truck and plan on keeping it for awhile. Any advice on engine parts or vendors are greatly appreciated.
Thanks in advance, Jamie
Intermittent heavy white smoke 04F250CC60 6.0L Power Stroke Diesel 11 08-23-2016 10:29 AM
F250 Blowing White Smoke Jeffd20038 1999 to 2016 Super Duty 3 08-17-2015 09:55 AM
Truck blowing white smoke?? breedo99 1994.5 - 1997 7.3L Power Stroke Diesel 10 08-17-2015 02:23 AM
blowing white smoke 6.4smokinstroker 1999 to 2016 Super Duty 3 11-15-2013 08:14 AM
blowing white smoke 6.4smokinstroker 6.4L Power Stroke Diesel 13 10-17-2013 06:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
