2014 Super Duty Wheel Offset and Tire Questions/Input - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-26-2013, 12:49 PM
RRRAVEN RRRAVEN is offline
RRRAVEN is starting off with a positive reputation.
Hi Everyone-
Hope all of you had a nice Christmas! I recently ordered a 2014 F-350 XL 4x4 Crew Cab and will be driving it home Saturday. It only took 5 1/2 weeks from the order day to dealer delivery date.........that was fast! I'm going to run the stock 245/75-17's on the stock 17" steel wheels during the crap weather but want to run something a little wider during the clear weather months. I plan on running either 17" x 9" wide wheels or 18" x 9" wide wheels with either 305/65-17's or 305/60-18's. Both tires are only about an inch larger in diameter and about 2" wider in section width when compared to stock. My question is if I want to basically retain the stock look and track width and not have the tires stick out past the fenders, what offset wheel should I go with? One of the wheels that I am interested in has a zero off set so 4.5" inboard and 4.5" outboard from the mounting surface. Does anyone know the offset of my stock steel 17 x 7.5" wheel? I'm not planning on any type of lift so I want to have the correct offset as not to have any tire rub. Any insight will be greatly appreciated!
Thanks in advance for all your help!
RRRAVEN
Old 01-02-2014, 10:25 AM
How do I move this post to the Brakes, Steering, Suspension, Tires, & Wheels Forum? Maybe someone there will have some feedback for me.
Thanks-
RRRAVEN
Old 01-02-2014, 11:19 AM
Wolfboro's Avatar
Wolfboro Wolfboro is offline
Wolfboro is gaining momentum as a positive member of FTE.
Off-set value of a tire rim is not a user-determined factor . It is part of the axle design that centers the weight (payload) over the wheel bearings . This is very important if you are hauling a heavy 5th wheel trailer or a gooseneck horse trailer or a slide-in camper . Use of a tire rim with a different off-set value "may be" harmless , If you are casually driving without any significant payload , but certainly it will put additional stress on bearings.
315 75R16 tires on what size rims aj1434 Excursion - King of SUVs 5 12-22-2016 06:36 PM
which wheels to run with cutout flares ufvj217 Excursion - King of SUVs 12 09-17-2016 07:18 PM
Backspacing/Offset Wheel & Tire Help Jeitutis 1999 to 2016 Super Duty 22 08-29-2016 12:04 AM
Rim offset book vs actual ThoobHertz 2009 - 2014 F150 2 06-19-2016 11:32 AM
04 FX4 Wheel Offset Hansen13 2004 - 2008 F150 2 11-12-2014 03:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
