Stock fuel tank, fuel line or evacuation? - Ford Truck Enthusiasts Forums
Old 12-26-2013, 11:16 AM
jimcar-9 jimcar-9 is offline
jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.jimcar-9 has a good reputation on FTE.
Hi guys, quick question
Where should the stock fuel line attach to the tank? Just beside the fuel gauge sender on top of the tank, or should that be the evacation? A friend belives that should be the evac, but I told him the evac is thru the gastank lid? But now I am not shure,
His fuel line is attached to the fitting in the bottom of the tank, what I thaught was a drain plugg only?
Can someone spread some light please?
Thanks in advance!
Old 12-26-2013, 11:17 AM
I am talking about stock 56 cab gas tank
Old 12-26-2013, 11:21 AM
Normalbloke Normalbloke is online now
Normalbloke has a good reputation on FTE.Normalbloke has a good reputation on FTE.Normalbloke has a good reputation on FTE.
You are correct. The top connection is for the fuel feed(you'll see it has an internal pipe almost to the bottom of the tank), the bottom plug is purely a drain point, and the fuel cap must be vented.
Old 12-26-2013, 12:03 PM
Great thanks, a big thanks!
Jimmy
Old 01-01-2014, 12:30 PM
Does anyone know more in detail how the vented gas tank work to let the air in but keep the gas inside (when full)
Old 01-01-2014, 12:44 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
It's usually just a rubber flap that seals it, but can bend inwards to let air in. The metal part of the cap has a path for air around the seal, a small hole usually.
Fuel tank replacement true blue 6.0L Power Stroke Diesel 10 11-08-2014 04:48 PM
KAM fuse and A/C repair Gnnut Ranger & B-Series 3 07-30-2014 05:34 PM
thermactor tubes on back of head Broncofever89 1978 - 1996 Big Bronco 7 07-16-2014 03:24 PM
Refill Radiator on 6.7L Hartwa 1999 to 2016 Super Duty 3 02-26-2014 07:24 PM
Ok A/C gurus... I need help Brown Falcon 1994.5 - 1997 7.3L Power Stroke Diesel 91 09-26-2011 10:04 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
