EASY......RIGHT? - Ford Truck Enthusiasts Forums
West Virginia Chapter Join Chapter, Leader: Archion
EASY......RIGHT?
Old 12-26-2013, 11:51 AM
4604wd4sp 4604wd4sp is offline
4604wd4sp is starting off with a positive reputation.
EASY......RIGHT?
1985 F-250 460/4sp/4wd Engine from 1977 lincoln-146 tooth flywheel with 351M starter. Eating starters like cereal!! maybe 5 starts per starter, also tried 460 and 390 starters. Now with the second 351M starter- ate flywheel. Thought I had it worked out....need actual Ford know-how here. Many thanks.....
Old 12-27-2013, 11:51 AM
I apologize-need to get used to specifics with Ford.
truck: 85 f-250 4wd 4sp
enigine: 460 '71 Lincoln D1VE6015A2B
bell hosing:d7ta7505ad
flywheel: 146 tooth
1st 3 starters-460, broke of nose of starter (started about 3 times each)
Replaced flywheel- 146 tooth
9 inch clutch
4th starter-351M, stripped gear on starter-not the teeth, starter engaged/spun (started about 10 times)
5th starter-351M, ground teeth off flywheel after 4 starts
Old 12-29-2013, 09:47 PM
gnwalker's Avatar
gnwalker gnwalker is offline
gnwalker is starting off with a positive reputation.
Have you tried the 460 or '80-'86 forum? Probably find a lot more info there
WTB: stock air cleaner - 460-4v F250 1977 shehan WTB - Parts & other 7 08-12-2014 12:43 AM
4wd FE to 460 frame brackets Magpie233 1973 - 1979 F-100 & Larger F-Series Trucks 8 07-09-2014 08:57 AM
EASY......RIGHT? 4604wd4sp 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 37 12-28-2013 09:38 PM
problems with 460-4 speed flywheel. help! mike79-460 1973 - 1979 F-100 & Larger F-Series Trucks 10 05-28-2010 08:29 PM
460 w/4-speed starters randall_1 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-04-2001 11:27 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
