02 V 10 fuel pump power - Ford Truck Enthusiasts Forums
Old 12-25-2013, 04:48 PM
stan'37 stan'37 is offline
stan'37 is starting off with a positive reputation.
I am in the process of replacing the fuel pump. I just wanted to see what power I had to the pump. I cut the pigtail off of the old pump, and plugged it into the power cord in the wiring loom to the pump. I thought I would have 12v to the pump. one hot, and one ground.What I found out is one wire has power all the time, Switch on or off,not 12v, but around 4-6 volt The other wire which I thought was the ground doesn,t do much Can anyone explain just how the power goes to the pump, or how to check the power from the two wires to the pump. Give me a Christmas present, Thanks, Stan
Old 12-25-2013, 07:25 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
The pump only gets power during initial prime for a second or two, then after the engine fires. If you measure in between that time, you'll usually measure a garbage value.
You have to measure it during that brief interval when the key is first turned from OFF to RUN if the engine doesn't start.
Old 12-27-2013, 12:50 AM
Thanks for the reply. I checked my pump wiring, that is how mine works. Then after the engine fires, does the pump run all the time, and bypasses the excess back to the tank? Thanks again, Stan
Old 12-27-2013, 05:47 AM
Yes, assuming a return-style and no FPDM. I think that's what you'd have.
Ex manifold studs 02 v 10 stan'37 Modular V10 (6.8l) 3 01-25-2014 01:39 PM
V 10 eingine oil stan'37 Modular V10 (6.8l) 1 01-10-2014 09:10 PM
Fuel pump replacement stan'37 Modular V10 (6.8l) 3 12-20-2013 11:16 PM
My fuel pump replacement stan'37 Modular V10 (6.8l) 1 12-19-2013 09:15 PM
Ford fuel pump stan'37 Modular V10 (6.8l) 2 11-18-2013 05:50 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
