Max PSI on a stock turbo
The following users liked this post:
I can't really speak to longevity but I just last weekend pulled the car trailer to VA. from Nashville, TN. This was the longest I've pulled the trailer with this truck and I towed in the tow tune from SPE with mild trans tuning. There were quite a few grades that made me nervous maintaining 65mph and boost was at 31Psi+ for miles at a time. Truck never skipped a beat. I'm much less concerned with the boost pressures after this trip as I don't hammer on the truck too often but it has seen 34psi before on on ramps and such. If it can take the constant pressure it took up those grades, the occasional full throttle blast shouldn't be to awful bad for her. Trailer weighs in at a little over 11k loaded (Pace Shadow GT 30ft)
So, if Ford designed the 6.7L Scorpion and powertrain to run 30+ psi in 450/550 applications, why do they make up excuses to deny our warranty claims when we add a tuner?
Not full on DPF delete (not that that should even matter), mind you, just any little piggyback. They'll warranty repair failed trans' and turbos in the "big truck" applications running a different turbo and no wastegate/much higher boost pressures, but they say if we want a few more psi, it voids our warranty? How does that work?
