Adjustable FPR on a 460? Need advice - Ford Truck Enthusiasts Forums
Old 12-25-2013, 02:17 AM
390Highboy 390Highboy is offline
390Highboy is starting off with a positive reputation.
So I installed a Holley adjustable fuel pressure regulator on my 90 efi 460. From the articles I have read, everyone says to set it at 41 psi. Does this mean 41 psi at an idle with vacuum line connected? Or disconnected? Or 41 psi at wot with vacuum line connected? I can't seem to find any info on it. I am currently running it at 41 psi at idle with the vacuum line connected, and it runs good with better power, but I don't want to screw it up.
Old 12-25-2013, 07:56 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
It baffles me why anybody would put an adjustable fuel pressure regulator on unless they are running a carburetor.
The fuel injectors need 39.2psi across them at all times for maximum fuel burn. That is what our era V8 Ford trucks are set to with a factory fuel pressure regulator.
A fuel gauge at the fuel rail will be from 30psi to 42psi depending on the V8 engines vacuum/pressure. This is to maintain the 39.2psi fuel pressure across the injector.
The ones who told you 41psi that would be with no vacuum (engine not running) with the fuel pumps running.
Old 01-01-2014, 08:53 PM
UNTAMND's Avatar
UNTAMND UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
Engine can be running, but only idle with no vacuum, and set it to 39-41 for the factory spec. With vacuum connected it will lower the pressure.
Why did you add this regulator.
I have used an adjustable regulator to help a lean condition in the upper rpm range of my 460. Mine just liked the extra fuel.
Please, help me spOUT! kjs5055 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 11-10-2016 06:51 PM
Fuel Pressure Help failsatheals 1997 - 2003 F150 5 06-21-2016 10:03 PM
1989 ford econline van 350 Jason Delamarter 1968-2013 Full Size Vans 3 05-30-2016 01:36 PM
Intermittent Power loss/ Bogging SomeDude451 1987 - 1996 F150 & Larger F-Series Trucks 2 09-01-2014 10:16 PM
96 Ford F150 4.9L PSI? JSTJ704 1987 - 1996 F150 & Larger F-Series Trucks 3 06-15-2014 11:17 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
