More Windhield Washer problems
My 2003 Expy EB 5.4 has a very annoying problem with the windshield washer system. When I activate the windshield washer the rear window washer sprays but no spray comes from the windshield nozzles. It is an intermittent problem and seems to be related to colder weather and higher elevations. On a recent trip from Arkansas to Washington it started acting up in Wyoming and continued until I reached the Puget Sound region (close to sea level).
I can hear the pump running and see spray on the rear window. The rear system functions normally. The front wipers operate when the spray button is depressed, just no spray from the front nozzles only the rear. Any ideas, anybody?
Thanks for the quick response. I found a diagram for the system and I noticed a check valve in the hose that goes to the rear washer. Is that just to keep fluid trapped in the line leading to the rear washer so the pump doesn't have to run as long to get pressure to the nozzle?
Thanks,
Ron
altascene
1997-2006 Expedition & Navigator
11-10-2016 09:05 PM
msuforeman
04-29-2008 05:16 PM
