Viper 5704 install questions?
THIS IS WHAT I DID ON MINE Alarm is fine, but I'm having issues with Remote start. Some one help.
I bought an alarm from amazon link:
And with tilt and glass sensor. I also purchased the PKALL module
This all into my 2008 F350 Diesel.
I've got the alarm working. Now I don't mind the delayed reaction to execute. But I'm having a problem remote starting the vehicle. I have everything wired as follows as I have done this before:
h1/1 red const 12v - tap to a const 12v TN/WH BCM
h1/2 black grnd - chassis ground Bk BCM
h1/3 brown siren out - connect to sirens red (black to ground)
h1/4 white/brown park light isolation wire - not used
h1/5 white park light out - out to parking light
h1/6 orange ground when armed out - not used
Door lock
1 blue out - tap to neg unlock - Pnk/LG
2 empty
3 green - tap to neg lock- Pnk/YL
Aux/shutdown/trigger harness, 24-pin connector
h2/1 pink/white ign/flex relay out - not used
h2/2 black/white neutral safety input - Run straight to grnd
h2/3 blue white 2nd stat/rear defog out - not used
h2/4 green black oem alarm disarm out - not used
h2/5 red/white trunk release out - not used
h2/6 green door trigger in - to my all door trigger underneath seat harness
h2/7 black/yellow dome light supv out - Opted to not hook this up
h2/8 brown/black horn honk - tap to horn
h2/9 dark/blue status out - not used
h2/10 pink ign out - to my ignition 1 along with the one on remote start harness
h2/11 white/black aux3 out - not used
h2/12 violet door trigger in - not used
h2/13 white/violet aux1 out - not used
h2/14 violet/black aux2 out - not used
h2/15 orange/black aux4 out - not used
h2/16 brown brake shutdown in - tap to brake wire
h2/17 grey hood pin - not used
h2/18 violet yellow starter out - not used
h2/19 blue instant trigger in - not used
h2/20 grey/black diesel wait to start - not used
h2/21 white/blue remote start/tt acvt in - not used
h2/22 orange acc out - not used
h2/23 violet/white tach in - not used
h2/24 oem alarm out - not used
remote start 10 pin heavy gauge connector
h3/1 pink ign in/out - DB/LG ignition harness
h3/2 red/white fused ign2/flex relay in - not used
h3/3 orange accessory out - BK/LG - ignition harness
h3/4 violet start out Rd/LB Engine side of starter wire ignition harness
h3/5 green starter in -- key side of cut starter wire
h3/6 red ign in - tap to const 12v lt grn/yellow BCM
h3/7 pink/white ign2 out - not used
h3/8 pink/black flex relay in - not used
h3/9 red/black acc/starter in - tap to const 12v lt grn/yellow BCM
the module was wired as per 2008 F350
any help would be greatly appreciated. Remote start is my task right now. I get a REMOTE START ERROR with nothing happening.
Thanks
Door lock
2 empty
Thanks
kawasakiklx1
09-03-2015 09:33 AM
Frozen001
1999 to 2016 Super Duty
08-19-2008 05:12 PM
