Install Dual Zone Climate Control in 2012 XLT?
#31
Tofan, good work. The unit I ordered is BC3Z19980N. I know mine is no heated / cooled seats, and I'm hoping it has the direct heated mirrors only switch. I'm not planning on doing the costly seats upgrade now. I don't believe the XLT has any of the wiring harnesses for power / heated / cooled seats in place; cooled seats requires A/C ducting to the seats. Are the seats memory? This would be another module. I don't even think my fuse box has the wiring in place to support this. Not saying it can't be done, just more difficult. For now, I am settling on the wood radio bezel, the auto climate controls (even if only single zone), and the factory Nav radio. Later this summer I will upgrade to the fancier instrument panel cluster with the LCD message center.
#32
#35
Trover,
I did the math with what it would take to install full black leather, heated and cooled seats. $3000 and it still is WAY less then what I would have paid for a Lariat. Also if I put everything else that I plan to do, I still don't top $5000 and in my opinion my truck will at that point be better then a lariat. Heated Cooled Seats, Black Leather, Tuner, Kenwood double din, and I will be done. I don't know, I know some people don't feel like tearing the new truck apart to do some stuff, but I have no problem doing it. I will own this truck until it dies and then will probably rebuild the motor/transmission, buy a new truck and keep this one for hunting/fishing.
#36
Tofan,
More power to you...if you do go down this route, please let me know. If it is relatively feasible, I might do it. I don't mind the cloth, but leather is easier to clean. Climate control panel arrives today, I will install this weekend and report back on Monday. Are you planning on adding the extra hardware to make your truck full dual-zone?
#37
Yes I am. As far as I know, it's adding an actuator and a little black box behind the actual console. Today is a holiday so I'm not at work, but I will give them another call to confirm. Yeah I will cover all the things that I do to the truck in a sweet video with instructions. It will be a long process but worth it in my opinion.
#38
#39
I installed the new auto HVAC controls last night. One note...I ordered part # BC3Z19980N, which is actually no heated / cooled seats but does have the rear window defroster (no heated mirror button). Previously, I thought I was ordering a unit with just the heated mirror button. It is not a problem, though. Pressing the heated rear window button heats the outside mirrors as usual. Installation was simple. Just make sure the trailer brake control module tab lines up with the slot in the dashboard behind it. As expected, everything functions 100% with the exception of the dual zone. Adjusting the passenger temp seems to cause the system to create and average of the two set temps, unless you set the passenger side to full hot or full cold, at which it does just that.
My last observation: the outside temperature display in the climate control does not always match the one in the message center! Sometimes it does, but most of the time it is off one degree...usually one degree less than the message center display. In a 3 hour drive last night, it never was off more than two degrees, and always lower than the message center display. Not a big deal, but where is the HVAC unit pulling its data from? I thought the temp probe was located in the outside mirror? Is it pulling it from the intake air temp sensor? Does this happen to those people who have auto climate control installed from the factory (e.g. Lariat / King Ranch trucks)?
Overall, a nice upgrade to the appearance of the interior, with a little more functionality even just using the single zone setting. Too bad my wood radio surround didn't arrive at the same time; I'll have to pull it all apart again next week.
#40
#41
Tofan, do you have the basic message center or do you have the 4.2" LCD one? I have the basic version; I'm planning on upgrading this soon. But I'm curious if this same temp discrepancy between the climate control and message center exists on those with the fancier cluster in XLT trim.
It actually doesn't look bad with the gray plastic surround; should look nicer in the wood. I'll try for pics soon.
#42
I have the basic message center, so when mine gets in, I will try to see if my temps are different as well. I think I will stay with the message center, I prefer that to the 4.2" message center. I can't wait until mine gets here. Oh BTW, I am gonna put my old manual control module on ebay to try and recoup some funds for different upgrades. After this one, I will probably do a tuner next, and then heated seats, cooled and finally leather.
#43
#45
