Power Steering cooler line leaking - Ford Truck Enthusiasts Forums
Old 12-23-2013, 09:22 PM
GG63Slim GG63Slim is offline
GG63Slim is starting off with a positive reputation.
I have 2002 F150 5.4L gas 4X4 Lariat FX4. Last winter when it got to -30C here in Manitoba one of the lines near the power steering cooler began to leak. I had just bought this truck and upon investigating found that the original line had been replaced and reattached with hose clamps. I had this "farmer fix" redone but then this winter when it hit -30C it blew apart. Obviously something happened to this line before I got it, so I am curious if there is an issue with these power steering cooler lines when it gets really cold. Should I just get factory lines installed and hope for the best?
Old 12-23-2013, 11:42 PM
Could the issue be with the cooler freezing up causing pressure to build up and burst one of the lines? Would a different type of fluid help if that was the case?
Old 12-24-2013, 06:14 AM
Lime1GT Lime1GT is offline
Lime1GT is starting off with a positive reputation.
If it's the high pressure line it shouldn't have hose clamps on it, they should be hydraulic crimped. The return line, which isn't high pressure, will usually have a standard ring clamp, similar to using a hose clamp. You might want to flush the steering fluid as you don't know what the previous owner may have used as a quick fix. I guess it's possible the pump's pressure relief valve may stick if the systems dirty. I live in Mb. and have never had issues with the steering on my 02. My brother's 03 did have slight seepage problems with the trans cooler line crimps when it was extremely cold.
Power steering fluid won't freeze. Check Rock Auto parts online and you'll see how the various lines should look.
Old 12-24-2013, 09:59 AM
Thanks Limey. I will check into which line it is and also look into the pressure relief valve. It only happens when it is really cold so either the hose shrinks enough to loosen the grip on the hose clamp, or the ATF gets so thick it builds up more pressure than the clamps can handle. I will get the proper lines installed and see if anything changes. I was posting on here to see if anyone was having a similar experience in the cold but it doesn't appear to be the case.
Power steering pump dun died? NewEnglandHerdsman 1999 to 2016 Super Duty 0 11-18-2016 01:04 PM
Power steering/hydro-boost problem matagilb89 6.4L Power Stroke Diesel 21 11-06-2016 08:09 PM
2000 ford f150 power steering goarmy56 1997 - 2003 F150 1 08-06-2016 10:23 PM
Power Steering oil cooler replacement rv7plt 1999 to 2016 Super Duty 3 11-13-2015 01:45 PM
Leaking Power Steering Line 1999_Explorer Explorer, Sport Trac, Mountaineer & Aviator 1 09-20-2015 04:28 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
