4x4 problems
If that is all good, no vacuum leaks...then the actuator (what the vacuum line attaches to), might be seize...they tend to do that from lack of use.
It can be removed and with your favorite spray lube (wd40, kroil, blaster...etc) & some simple tools you might be able to get this to free up.
more info you may find useful
Rebuild Kit BW4406 Transfer Case and Parts plus Illustration drawing and parts list! - Drivetrain.com
or
4x4 Woes - F150online Forums
doubtful if any "inline fuses"....but
so you checked the #3 & #23 fuses and the larger "maxi fuse #104...yes?
So...also...No vacuum leaks to the actuator and the plunger rod under the actuator moves freely.
Also...the T-case has correct oil and level in it.
^^^ all true^^^?
have you had a front windshield replaced or is leaking?
Is there anything else strange going on inside the cab...lights flashing or turning on or shutting off? The Heater and A/C is placing air where it is suppose too?? also check for vacuum leak...behind the battery.
you probably need some assistance checking the T-case motor....check the amp draw as the switch gets rotated to each position. maybe the T-case motor is weak??
or maybe the switch on the dash is not providing power to the T-case motor...hopefully a simple switch is all or a bad wire....but....
there is a "GEM" module inside the dash that controls the tranny and T-case and other major fuctions, that can short out...usually if that happens you get all kinds of strange electrical activity...I think it ties into the anti theft...so it maybe a dealer only replacement?...so that they can tell all the electronics that everything is OK after the replacement.
more info on GEM >>>https://www.ford-trucks.com/forums/1...ogramming.html
^^^ all true^^^?
If if works I 4 low but not 4 hi than it is the gem module or selector switch. 4 hi and 4 low use the same wires and relays to move the encoder motor. What you are hearing is the relay for the synchronization clutch inside the transfer case. Since the gem is sending a signal to the clutch relay but not shifting the case I would go with the gem module having an issue.
superduty4x4
02-10-2010 02:48 PM
