computer fried? (pic)
I bought a 94 f150 4.9/E40d a couple weeks ago. The truck only has 89k miles and is really clean and original. It's had a bit of a high idle since I got it, but otherwise rand great. Unplugging the iac did not affect the idle at all. I tested the iac, tps, checked for vacuum leakes and everything checked out good. Now when you press the gas pedal the truck wants to immediately stall out. I pulled the computer tonight to have a look inside and found this. Could this cause the problems I am having? I'm guessing either way the computer needs to be replaced. Thanks for any advice.
on
Well actually that may not be far from the truth, leaking electrolytic capacitors are a known problem with these PCM modules(or any electronics that is 20+ yrs old) but unless they completely short out and burn up the board then it's entirely possible the module can be salvaged by simply replacing all those little oil can looking things. If you are at all handy with an electronics soldering iron or know somebody that is then it won't take more than a few minutes to replace the capacitors , just make sure they are the same uF or mfd value, the same or greater voltage rating, and are installed with correct polarity... look for a + marking on the board under the cap or take pictures and put everything back the same way.
True, and I was outraged with Ford and their dozen or so different PCMs. Mine was destroyed! The caps leaked out and ate through the traces on the board. I wish I could record what I really had to say when I started looking for the replacement. I'd you do a search at O'Reilly auto parts, there are a lot of different PCMs..and since I didn't have ime to trial and error, I ponied the money so I would know I had an identical PCM. My PCM was coded, T2D1. There were cheaper ones, but I can't gamble on a vehicle if its not running. I also tried replacing the caps and jumpering the breaks in the traces, but the fuel pump ran continously.
Do not be surprised if that Cardone "remanufactured" PCM is DOA. Cardone is notorious for repackaging PCMs with new stickers and no testing whatsoever. Good luck...
We will see. What other choices are there? It seems that there are only a couple companies that reman them.
Standard Motor Products (SMP) is my favorite: Standard - eCatalog
These two places could repair yours and come recommended from other FTE members:
Auto Computer Exchange | Remanufactured OEM Auto Computers
Ecu Repair Now, automotive circuit board testing and repair
You'd been better off repairing yourself or having yours repaired local first, odds are pretty good it work fine again once those caps where replaced.
Don't wanna take it on yourself any local TV repair shop or any place does board level electronic repair work should be able to handle the job and for around 20 bucks or so.
About a 15 minute job change those caps for a guy does that kinda work every day and should be able to tell you by looking at the board what its chances are once the caps are replaced. Damaged and beyond repair, or real good chance it will be just fine was caught it in time.
