throttle solenoid question - Ford Truck Enthusiasts Forums
Old 12-23-2013, 03:16 PM
lazzarruss lazzarruss is offline
lazzarruss is starting off with a positive reputation.
im trying to figure out some wiring. My fuse box has a fuse for the "throttle solenoid". I am looking over several wiring diagrams, but im confused about some of the naming. is the throttle soenoid and the Idle stop solenoid the same part? I have two wires (ones solid gray, the other is either white/black or black/white)going to a connector through my firewall on the passenger side that connects to another "two pin connector but the connector it connects to has a single wire coming out of it. this wire is just loose. Im about 90 percent sure this goes to the "anti-dieseling" solendoid on the driverside of my carb (2150 2bbl), but I would like some feed back. The solenoid on my carb has a broken wire that also is not connected.
Old 12-23-2013, 06:50 PM
Roger Carter's Avatar
Roger Carter Roger Carter is offline
Roger Carter is gaining momentum as a positive member of FTE.
I have seen where Ford will call the same part by different names in their shop manuals, parts catalogs and various other publications.
Pretty sure the "throttle solenoid", the "idle stop solenoid" and the "anti-dieseling solenoid" are the same, just different names.
My '78 S-cab has a two wire connector with two wires coming from it. One goes to the electric choke and the second goes to the solenoid in question.
If it was a bit warmer and not raining cats, dogs and an occasional frog I would check the wiring colors. But that will have to wait for another day.
Roger Carter
Throttle solenoid wire to AC FilmCarp Cooling, Heating, Ventilation & A/C 0 05-03-2015 03:13 PM
Need Help with 3G Swap Please VaFordman26 1973 - 1979 F-100 & Larger F-Series Trucks 57 04-09-2015 06:32 PM
1997 Aerostar Starter Relay Solenoid Wiring bajabob Aerostar 5 11-11-2014 07:59 PM
1992 Ford F150 4.9L 3g Upgrade zoom38 1987 - 1996 F150 & Larger F-Series Trucks 38 03-30-2013 07:06 AM
1st of many wiring questions - EZ Wire to 5.0 ferguson777 1948 - 1956 F1, F100 & Larger F-Series Trucks 32 07-07-2012 07:27 PM
Tags
idle, solenoid, stop, throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
