Banjo Bolt - o-ring? crush washer?
Old 12-23-2013, 07:53 AM
OldWoodsDiesel's Avatar
OldWoodsDiesel
OldWoodsDiesel is offline
I am beginning to gather parts for my e-fuel setup and think i'll go with the banjo bolt adapter from this thread: https://www.ford-trucks.com/forums/1...l#post13871919
the part itself is not cheap ($20 from McMaster or Parker, reportedly $12-15 elsewhere), but I figure it should save me at least that much in new fittings and stainless tube and probably much more than that in time.
my question is - does the stock banjo bolt have O-rings to seal it to the fuel pump and metal ring of the fuel lines? I'd like to replace all these sealing elements while I've got it apart and thought someone may know the size and type of such parts off-hand.
thanks!
Old 12-23-2013, 08:17 AM
ReBilld's Avatar
ReBilld
ReBilld is offline
There are two metal washers on them, one on either side of the banjo fitting. I think Riffraff sells new ones.
Old 12-23-2013, 08:33 AM
OldWoodsDiesel
would you say they are reusable, or should they be replaced being tightened down once?
thanks bill!
Old 12-23-2013, 08:43 AM
ReBilld's Avatar
ReBilld
ReBilld is offline
I'd probably replace them.
Old 12-23-2013, 09:00 AM
mjunk1's Avatar
mjunk1
mjunk1 is offline
+1 on that - if you are in there that far it seems like a great insurance policy to make sure you don't have to pull it apart later.
Old 12-23-2013, 09:41 AM
OldWoodsDiesel
that was my thinking. I guess i'll see if parker has something that'll work when I go pick up the adapter. otherewise, i'll order from Clay.
thanks guys.
Old 12-23-2013, 06:20 PM
fordman67's Avatar
fordman67
fordman67 is offline
I just can't imagine reusing that thing...better mount it once the pump is gone and replace the seals at the head fittings also.
Old 12-23-2013, 06:53 PM
OldWoodsDiesel
Aren't the fitting that go into the rear of the heads AN fittings on 1/8" npt adapters? If so,I figured there are no o-rings there to wear out so I'd leave well enough alone and save a few bucks.
I plan to do this setup on the cheap, but def pressure test the system on the stand before installing the engine.
Old 12-23-2013, 08:43 PM
fordman67's Avatar
fordman67
The fittings are npt but the lines have a seal where they meet the fittings.and i despise that banjo arrangement.just my opinion.do what you want to.
Old 12-23-2013, 10:28 PM
OldWoodsDiesel
Well that changes things. I thought it would just be a flared end on the tube end connecting to the npt adapter.
It really would be a pain to have a leak back there after putting the engine back in. I will pressure test on the stand, but maybe new lines back there are in order after all.
Those threads in the heads (front and back) are 1/8 NPT, though, right?
Old 12-23-2013, 11:38 PM
fordman67's Avatar
fordman67
the rear stock line seals can be replaced without tearing much out. I just dont like them IF I am redesigning I am eliminating such things.
the factory fittings Bill uses 5/16 line ,compression ferruls and nuts then builds hard lines forward. I did not do mine like that but after doing it my way,I like his much better.
Yes the head is 1/8" npt
Old 12-24-2013, 09:33 AM
OldWoodsDiesel
Yeah, knowing there're rubber seals in there, I think I'll nix them as well. Those seals are probably only rated for 10 yrs or something anyway. I tend to hate compression fittings, but that may be an irrational hatred based on the ineptitude of whoever connected up my heating oil tanks :-)
Maybe I'll think about flare fittings. Bill - did you use stainless or copper? It looks like the stock fittings are brass back there. Hard to tell on the lines - I haven't degreased yet :-)
Old 12-24-2013, 11:33 AM
fordman67's Avatar
fordman67
The stock is brass. i used steeel jic fittings.I'm thinking hard about doing hard bent lines to the jic fittings . I'm going to check on tube nuts and flare the line.
Old 12-24-2013, 12:09 PM
OldWoodsDiesel
Cool. Yeah, that's what I wound up doing to fix my oil heater lines. Lots more pressure here, but hopefully will be pretty robust.
Old 12-25-2013, 06:18 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
I just used 5/16" steel line.
nolszewski
57
11-12-2020 02:10 PM
kmorelli1
05-07-2018 03:29 AM
ved0303
05-11-2015 12:23 AM
Redneckmorton
06-23-2012 05:17 PM
tubolove
16
02-27-2008 05:23 PM
Quick Reply: Banjo Bolt - o-ring? crush washer?
