1979 F150 am radio ...Looking for Am / FM Radio conversion - Ford Truck Enthusiasts Forums
Old 12-23-2013, 08:17 AM
GOLFER1ESS GOLFER1ESS is offline
GOLFER1ESS is starting off with a positive reputation.
1979 F150 with a am radio ...Looking for Am / FM Radio conversion
Any one able to assist? See a few on eBay for $159 but I take it I have to cut wires...
Thanks guys
Old 12-23-2013, 08:29 AM
RunninD's Avatar
RunninD RunninD is offline
RunninD is gaining momentum as a positive member of FTE.
Depends on what you want to spend, and what you do or don't want to do to your truck.
I wanted it to look bone stock, and retain the No battery drain function that the original radio had, so I took my radio out and took it to a local guy who wired an auxilary input jack into it. When you plug something into the jack it supercedes the Antenna input and your I-pod or whatever then plays through your still stock radio. My I-pod plays local radio channels, so total cost $20
Kicker makes a small "hidden" unit that you can wire to the speakers and that plays and controls an I-pod The unit charges, and controls the I-pod, and you basically then ignore your stock radio. Cost $200 plus an I-pod
Several guys have made the swap / conversion to the DIN style head units with just a little Fabbing. Cost is dependent on the system you install.
Old 12-23-2013, 08:54 AM
cr500monster cr500monster is offline
cr500monster is starting off with a positive reputation.
i had pulled my radio/defrost bracket out and made a new one to hold a new style radio , any sheet metal shop should be able to do that if its the direction you would want to go
Old 12-23-2013, 09:55 AM
I have heard that the stock AM speaker will not play fm music... is this true?
Old 12-23-2013, 10:12 AM
VocaTexas VocaTexas is offline
VocaTexas is gaining momentum as a positive member of FTE.VocaTexas is gaining momentum as a positive member of FTE.
Quote:
LOL! NOT TRUE! Now, the old speaker may be in bad shape and not sound good, but as far as a speaker is concerned, it doesn't matter whether it's getting a signal from AM radio, 8 track or Sirius, it's all the same.
Old 12-23-2013, 02:47 PM
miketaheny miketaheny is offline
miketaheny is starting off with a positive reputation.
I bought one from these guys and thought it was the best bang for the buck.Vintage Car Radio .com
It was an exact fit but I don't remember the details of the wiring so I assume there was no issues there either..
Old 12-23-2013, 06:56 PM
JWC 3's Avatar
JWC 3 JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
I left my stock radio in place . I hate to cut up my dash . I got a CB mounting bracket and mounted an aftermarket radio under the dash like you would mount a CB radio . Now I have a modern radio/cd/Mp3 player etc. and no chopped up dash . I did something similar in my 65 years ago . Just a thought !
Old 12-24-2013, 12:31 AM
1979 300i6's Avatar
1979 300i6 1979 300i6 is offline
1979 300i6 is starting off with a positive reputation.
Quote:
Originally Posted by miketaheny View Post
I bought one from these guys and thought it was the best bang for the buck.Vintage Car Radio .com It was an exact fit but I don't remember the details of the wiring so I assume there was no issues there either..
yeah I did the same, and I love it, looks factory and pretty much went in with no problems. Best thing is there is not cutting and plus a AUX
Old 12-28-2013, 11:34 PM
RunninD's Avatar
Golfer, the AM will play the FM stations it just doesn't receive them due to the wrong frequency. if you bypass the input (the antenna) and use your I-pod like I did with mine it plays everything that it gets fed. The signal is decoded by the I-pod so there is no issue.
Old 12-29-2013, 02:15 PM
riverbedjedd riverbedjedd is offline
riverbedjedd is starting off with a positive reputation.
am/fm tuner
Have you looked at retrosound.com They make some awesone vintage looking am/fm tuners that you dont have to cut your dash for at all they fit i n the stock harness i just picked one up for my 1975 ford f250. They have usb inputs, bluetooth, handsfree calling the whole works built in crossover if you wan't to add subs later. a little pricey at around 299.00 but you don't have to cut your dash and you can keep the stock look
Old 12-31-2013, 05:11 PM
Still looking for a stock looking AM/FM Unit i can wire in....
Old 12-31-2013, 08:28 PM
Dave145's Avatar
Dave145 Dave145 is offline
Dave145 is starting off with a positive reputation.
Look for a stock on on eBay???
Old 12-31-2013, 08:33 PM
LMC sells some
Old 12-31-2013, 08:38 PM
JWC 3's Avatar
Quote:
LMC has stock "looking " units . I am too cheep for that . That is why I mounted a modern radio under the dash with a CB mount . Easy to remove , no chopping the dash . When I was into VW's years ago , there was a company , you could buy a "hidden " stereo . It went in the glove box . Sure they are still around . Many options . Some cheep , many not .
Old 12-31-2013, 08:39 PM
Not seeing any on eBay ...
1979 f150 radio Ronnief150man 1973 - 1979 F-100 & Larger F-Series Trucks 7 11-06-2016 06:30 PM
am/fm radio Satch 1997 - 2003 F150 3 01-29-2016 08:35 PM
WTB '83 factory am/fm stereo radio Hound Dog Lew WTB - Parts & other 2 11-02-2015 09:19 PM
Factory radio problems Josh726 1973 - 1979 F-100 & Larger F-Series Trucks 5 06-09-2015 08:39 PM
Looking for a AM/FM Radio 1979 F150 GOLFER1ESS 1973 - 1979 F-100 & Larger F-Series Trucks 9 01-08-2014 01:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
