How to bend hedder?
Old 01-02-2014, 11:28 PM
SuperDuty93's Avatar
SuperDuty93
SuperDuty93 is offline
Unhappy How to bend hedder?
So I got my 428 in and my new headman headers actually fit a highboy well... Well a stock highboy. The problem is since I have a 78 dana 44, the high pinion brings the driveshaft up and therefore rubs the driveshaft, and would hit it hard if the springs compress offroad. So I deed to bend the headers a half inch or so towards the driver side leaf springs. No idea how to bend these guys though....
Old 01-02-2014, 11:45 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Ratchet strap around the frame or other immovable object! However, metal has memory so it would need to bend farther than what ya need. Doing so also risks cracking or crimping the tubing.
Personally, I would perform a very narrow pie cut on the collector tube, angling it slightly, and then re-welding it closed.
Old 01-03-2014, 12:04 AM
SuperDuty93
Hmm it hits the collector ring with the 3 holes in it.... Wonder how hard the metal is cuz that would be idea if only the mount ring had to be trimmed...
Old 01-03-2014, 05:34 AM
HIO Silver's Avatar
HIO Silver
Ah, it wasn't clear by your first post where it hit. Mine is close too (FE, Hedman long tubes, with a HP D44). My simple fix was to clock the collector flange and it misses by about 3/16-inch. Real close but it has never hit.
Remember that the front suspension (and summarily the front driveshaft) cycles up and down with very little lateral movement since assembly located by the track bar. The driveshaft will rotate a bit along the vehicle's longitudinal axis but when only one side is reacting to an obstacle.
Half an inch seems excessive. Is your axle centered to the frame? We all know by experience that manufacturing tolerances back in the day were less than accurate - throw in more dimensional differences with a lift and those "errors" really start to stack up. That's the reason I opted for an adjustable track bar from Superlift. I went as far as dropping plumb bobs off each frame rail down to the axle to make sure it was dead nuts centered.
Old 01-03-2014, 09:55 AM
SuperDuty93
Hmm I'm not home right now but ill take pics of what's up. I didn't do the swap the PO did it and I did notice the front driveshaft is a bigger diameter then the rear and I know my highboy has a little spring sag. But yea it barely hits the flange and one tube rubs the crossmember as well so needs yo come down 1/8" and over maybe a 1/4" I guess. Other then that iys a gorgeous set of ceramic headers
Old 01-05-2014, 08:18 PM
SuperDuty93
Ok here are some pics.
Old 01-05-2014, 08:28 PM
co425's Avatar
co425
co425 is offline
Cutting into a ceramic coated header ruins the coating. Unless you plan on recoating. I'd trim the crossmember before bending in the one direction. Also think about having a smaller diameter driveshaft with the same thickness tubing made. If it's the stock shaft it's probably time for a rebuild anyways.
Old 01-05-2014, 08:37 PM
SuperDuty93
Idk $500 for a new driveshaft around here But maybe I can find someone who will ship me one and can make it and ship it for cheap. And yea ill try to trim the crossmember
Old 01-05-2014, 09:27 PM
HIO Silver's Avatar
HIO Silver
Oh, the header is ceramic coated... that would have been important to state in an earlier post.
Here's something to check... is the engine level side to side? Meaning, is it clocked to one side and causing the header to hit? Look at the motor mount stud and it should be centered in its mounting hole. If it is, ya might be able to cheat by slightly clocking it to take care of that header clearance issue. However, with a manual trans the Z-bar will no longer be level.
If that fails, grind on the crossmember. Aim for at least 1/4-inch clearance to account for the engine torquing over.
Old 01-05-2014, 09:41 PM
co425's Avatar
co425
co425 is offline
Too bad your not closer. I could cut that section out and weld back in a section of tubing for you for clearance.
Old 01-05-2014, 09:44 PM
SuperDuty93
Leme go look!
I bet the engine is at a slight angle.....
Old 01-05-2014, 10:47 PM
HIO Silver's Avatar
HIO Silver
... and keeping my fingers crossed.
Old 01-05-2014, 11:29 PM
SuperDuty93
lol sorry. Chargers just rolled in on the busses down the street so we all went down to welcome them back and honk the train horn as we drove by g
But no engine is good.
Old 01-06-2014, 01:23 AM
co425's Avatar
co425
co425 is offline
Take your air cleaner off and put a level across the carb. I've had mounts that weren't square. Worth a shot at least.
aharleycpl
04-07-2016 09:30 PM
bulletsneverlie
05-29-2010 04:22 PM
Knucklebuster
31
08-20-2006 07:22 PM
mustange70
Offroad & 4x4
12-24-2005 02:02 AM
Sixoh
03-22-2004 11:03 AM
Quick Reply: How to bend hedder?
