water in my wvo? - Ford Truck Enthusiasts Forums
water in my wvo?
Old 12-22-2013, 11:24 AM
onthemoveactivist onthemoveactivist is offline
onthemoveactivist is starting off with a positive reputation.
water in my wvo?
I have a wvo system from golden fuel systems. I have been running it fine for about 2000 miles. The other day I got some wvo and the engine would run really bad and stall. I drove it for 4 hours constantly switching from diesel back to wvo to try and burn it off. half way there I filled the wvo tank with diesel to try and dilute out the bad stuff it got better but still was bad. Is it possible that there was water in the wvo when I pumped it? It looked ok but you never know. What are some symptoms of water in your fuel? and I thought that this big filter for the wvo system was supposed to keep water out. Any ideas?
Old 12-23-2013, 09:42 PM
444dieselrod's Avatar
444dieselrod 444dieselrod is offline
444dieselrod is gaining momentum as a positive member of FTE.444dieselrod is gaining momentum as a positive member of FTE.
Did it run better on #2 but still bad on WVO?
Are you sure your filter is a water block filter? if not then the water will go right through it like fuel.
Water in a diesel is pretty easy to spot, they generally run like crap if at all since water won't combust like diesel. This is also why all diesels have a water block fuel filter.....
Drain your WVO/#2 mix and let it settle for a few days, you will see the water on the bottom if its in there.
Diesel Rod
Old 12-24-2013, 12:02 PM
timmyboy76's Avatar
timmyboy76 timmyboy76 is online now
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
when was the last time the wvo filter was replaced?
Old 01-09-2014, 12:53 AM
genscripter's Avatar
genscripter genscripter is offline
genscripter is starting off with a positive reputation.
Uhhhh.... Did you do a pan test?
Old 01-13-2014, 01:42 AM
finitetime finitetime is offline
finitetime is starting off with a positive reputation.
What engine do you have and what year?
1985 f250 with Golden Fuel WVO system Hedonloki Bio-diesel, Propane & Alternative Diesel Engine Fuels 3 02-02-2016 08:00 PM
Running ambient temp WVO in dual tank IDI lio45 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 08-03-2012 04:52 PM
1994 F250 Diesel. Biodiesel? WVO? Junkman of Delaware 1987 - 1996 F150 & Larger F-Series Trucks 2 08-10-2011 12:03 AM
WVO Blends IceboxFX Bio-diesel, Propane & Alternative Diesel Engine Fuels 31 06-29-2008 06:33 PM
WVO - the best idea parkland Bio-diesel, Propane & Alternative Diesel Engine Fuels 17 03-27-2006 04:02 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
