Air noise from front of Engine?
Hello
I have an 2006 F350 6.0 liter diesel with about 115000 miles on it. Recently I have noticed a rushing air noise when revving up the engine. It seems like it is on the passenger side in the front of the engine. I have new rubber boots from riff raff diesel (very tight) and the turbo builds pressure up to about 30 psi. Would the turbo build pressure with an intercooler leak loud enough to hear like mine? The noise does not appear to be coming from the turbo itself. Any advice would be appreciated. The truck seems to have power. Where could the noise be from???
Thanks
dogdoc
Thanks
dogdoc
Hello
Thanks
dogdoc
Thanks
dogdoc
Unless it has Been hit by a rock and has a hole in the surface, the most common failure of the intercooler it's self is where the plastic tanks seal on each side. It's possible to pull the rubbery plastic dust shield back a little and peek in with a flashlight. Look for blue or orange color o-ring bulging out where the tanks are crimped on. If you see any color it's probably leaking a little. If it's just starting to leak, it will fail soon and a longer piece the seal will be hanging out, hard to miss.
Sent from my Sprint PC36100 using IB AutoGroup
Here are the end tanks: http://www.bulletproofdiesel.com/Do_...pgrade-kit.htm
