Best Engine Cleaner/Degreaser
The above cleaners work well
The below links for WAB PRODUCTS is what most over road and local trucking companies use with cold water pressure washer. The results are great. Every truck stop and truck dealer sells it.
ENGINE & CHASSIS
Home
ENGINE & CHASSIS
Home
I use Gunk Engine cleaner and Simple Green. Both can be found at Walmart.
https://gunk.com/products/cat_det.asp
ENGINE & CHASSIS
Home
ENGINE & CHASSIS
Home
I use the purple cleaners and sometimes the Gunk and follow it up with either a hot water hose or sometimes I fire up the Hotsy. I have never covered anything in the compartment on any vehicle and never had a problem, just don't dwell on electrical, vented caps, soft items, etc.., you get the idea.
on
Consensus on FTE has always seemed to be to cover those couple of areas, and use LOW pressure water, as in a hose with maybe your finger over the end. When you've got it down on your truck, run by my place and clean my trucks too!
timbuctooCal
06-26-2014 03:35 PM
ldcattle
13
05-29-2006 05:49 PM
