2.0 distributor removal
on
Been a while since I messed with one, but as I recall, you do everything from the top. Two flathead screwdrivers at opposite sides of the reluctor with a gentle prying motion should pull it straight up and off the distributor shaft, it's located by a small roll pin (don't lose it!) in a slot.
After that, it should be easy to remove the pickup coil mounting plate, and be sure to check the centrifugal advance to make sure it moves easily and that it's greased.
jobrewer1983
12-08-2009 08:47 PM
78bigunns
33
06-30-2008 09:35 AM
'86_150
01-26-2008 09:12 AM
jimlj
10-17-2005 08:47 AM
