stupid heat! - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
stupid heat!
Old 12-21-2013, 07:10 PM
yjONtheLID1984 yjONtheLID1984 is offline
yjONtheLID1984 is starting off with a positive reputation.
stupid heat!
Ok so i just got this damn truck back from the shop after over a week for the blendor actuator to be replaced and the clock spring, drove it maybe 7 miles home and it sat all day and half of today. I drive it for maybe 25 minutes today and only put the heat from the dash vents to the defrost and turn the fan speed down and now i have no heat again on the drivers side, just cold air. WTF? The shop that worked on my truck said the actual control panel is what made it break to begin with. Anyone have any ideas whats up with this
Old 12-21-2013, 07:18 PM
02TB250's Avatar
02TB250 02TB250 is offline
02TB250 has a great reputation on FTE.02TB250 has a great reputation on FTE.02TB250 has a great reputation on FTE.02TB250 has a great reputation on FTE.
What year and motor. Trim level?
Sent from my Galaxy using IB AutoGroup
Old 12-21-2013, 07:26 PM
Its an 08 f350 drw lariat with climate control
Old 12-22-2013, 09:02 AM
6.4 as well. Thought i threw that in there
Old 12-22-2013, 10:09 AM
ashleyroachclip ashleyroachclip is offline
ashleyroachclip is starting off with a positive reputation.
So are you saying you have heat on the passenger side , but not the driver side?
Is this a dual temp zone ie several controls for the two sides?
Old 12-22-2013, 10:33 AM
I have heat on the passenger side butncokd air on the drivers side. I just had the blend door actuators replaced and the clock spring and not even 45 minutes of drive time on the truck and its acting like the actuator on the drivers side has broke already. Its dual climate controlled
No heat in my 98 ranger jimmy76 Ranger & B-Series 8 08-23-2015 10:45 AM
Whatya know about exhaust heater valves? 78 F150 hermancm 1973 - 1979 F-100 & Larger F-Series Trucks 0 07-23-2014 06:39 PM
Heater issues mblayton 1997-2006 Expedition & Navigator 2 02-09-2013 09:44 PM
Efficiency of a heated floor? fellro86 Garage & Workshop 18 05-08-2012 09:13 PM
1997 F150 heater problems BdWis 1997 - 2003 F150 5 04-08-2011 05:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
