TAD Missing
TAD Missing
I had a TAD(Thermactor Air Diverter) valve (I think). At any rate I was in the process of replacing the oil pan and valve cover gaskets, new spark plug wires, coil, and rotor cap, when I noticed that the TAD was missing.
I've got one on order from a Ford dealership.
Will the fact that the TAD is MIA cause any problems if I start the engine and run it?
Thanks
Guy
Thanks
Guy
Thanks for your reply Paul... I forgot to mention that it is the solenoid.
I have the Thermactor Air Bypass Solenoid. I'm apparently missing the Air Diverter Solenoid. But as I look at the Thermactor valve assembly ..it looks
like a "single" Valve is doing "double-duty" i.e. working as both the Air Bypass and Air Diverter valves
I'll go ahead and start it and do a test drive.
Thanks again
Guy
Thanks again
Guy
Not sure but believe it has all to do with cubic inch displacement? but might be wrong....
My 351 doesn't have the Thermactor Air Bypass valve it never did, it had no tube directly down to cat, tube to back of each exhaust manifold only.
It has the Thermactor Air Diverter only, directs air either to atmosphere or into manifolds handling both jobs all in that single device.
460 on the other hand (both trucks over 8500lbs gvwr), 460 has air via tube down to cat or to manifolds.
No air required the Thermactor Air Bypass valve dumps it to atmosphere right behind the air pump, air required system either sends into manifolds or down directly into the Cat via the Thermactor Air Diverter mounted up on the engine. system uses both valves rather than just one, the when and why part I don't know never got into it that deep. That air feed directly to cat or into the manifolds instead part.
351 I eliminated the cat and later remainder of air system, don't get any codes even though vac lines are gone with it, left its control solenoid electrically active.
As Paul pointed out only aspect of the system the computer is aware of, the tab/tad solenoid/s, retain it get no codes.
alloro
1997-2006 Expedition & Navigator
04-28-2015 09:59 AM
OldKingCole
13
04-30-2014 08:42 PM
krazdndenver
08-29-2002 04:43 PM
