1995 EFI 460. E4od swap for zf5. Worth it?
Is there anything wrong with the E4OD?
It is worth the swap if you want to go manual. Also, you want to get the manual transmission ECU when you swap over. The automatic transmission ECU will not like having the E4OD not present! Nothing but codes and probably go into limp mode killing what ever MPG the 460 could give after the swap.
The swap has been done many times before and just a search(E4OD to ZF5 swap) here will bring up more info.
I believe it's a internal leak( valve body probs). I man shift 1 2. To OD. TO DRIVE IT. We dropped valve body to replace gaskets couple yrs ago and stabbed VB back to shell. Got it together. Then no R with same forward issues. I'm sure my "trans" master buddy got check ball or spring off causing no R Gear but I think forward prob is whorpt shell/ VB.
That's what's wrong. I just would rather go man and not have to deal with autos and their expense
imabass
07-06-2017 11:45 AM
bikeymikey
10-17-2016 09:10 AM
BleuHawke
11-10-2015 02:43 PM
danlee
19
07-06-2013 11:11 AM
