Is 16.5 mpg average?
We're on the road in our first trip in an 02 F250 4x4 we bought this week. On relatively flat road between Houston and Dallas, and driving cautiously like around 65-70, I got 16.44 mpg. Today, from Ft. Worth to Raton NM, driving 75-80 mph and climbing 6,000 ft. thru the day, I got 14.8 mpg.
Are these pretty much standard mileage numbers? Should I be able to improve upon this? Truck wasn't loaded, other than two adults and normal luggage.
Im curious to see some responses. I got my 2000 f350CC in August and at best I was getting 17.25mpg and it has been slowly declining to the last fill up at 13.06mpg. It has been pretty cold around the northeast so i dont know if it could be the extra time that I allow the truck to warm up or maybe its just not running as efficiently bc the engine is taking longer to reach ideal operating temp.
Winter fuel and warmup time is going to kill your mileage. I average 16ish in the summer and 14ish in the winter.
Driving all highway keeping it under 2000 rpm (68mph) I can get from 18.5-20.5mpg based on my records.
My bone stock '97 2WD (with reman stock injectors) bested at 23mpg highway completely empty, and routinely hit 19-20 on mixed driving, including inner city Philly commute to work. On the summer camping trips from Philly to Lake George in upstate NY, filled with gear and towing a boat, she'd get about 16-17.
My '99 4x4 has never seen anything better than 18, and that was on the highway drive back from Denver. My local was 14-15. I expected a drop with the switch to 4x4 (all else is essentially the same), but with all the "improvements" from 97 to 99 I'm surprised the drop is as bad as it is.
Everyone who already responded has covered everything I would say. Winter fuel drops mileage a bit, I would say just to be more accurate, fill all the way to the top of the tank, take your time and get it all the way up the fill neck, and hand calculate, don't trust the lie-o-meter. 16-17 is about average on highway driving 70ish.
Things could always be worse. I've been getting a solid 8mpg since finding my drain valve leaking. It's now fixed, and has not improved. Haven't had time to source a possible second leak yet, but I'm pretty sure it's the passenger side head port as my starter is all diesel-y.
There is no way you should be happy with less than 34.2228 miles per gallon with one of these 8000+ lb. bricks. If you're not getting at least 30, something's wrong with your truck.
Well, if you listen to the guys who are filling up (and bragging up) their diesel pickups standing next to you at the fueling station, that's what they're getting. If you don't believe them, just ask them and they'll tell you.
Received 3,101 Likes
on
their gold plated comeaparts make 900 hp and 1800 ft lbs torque, get 35 mpg idiling, and actually make fuel when driving.
the ford drivers will tell you they are lucky to see 12-13 mpg.
16.5 is the best I've ever gotten unloaded driving like a grandpa in the slow lane empty. 14 is what I average beating the snot out of the skinny pedal...... 2mpg..... Who cares.... Hammer down!!!!
I drive my jetta for mileage.... I bought my truck to have a truck and a toy 14 I'm still happy with. Keep in mind you're fueling 444 cubic inches of engine with a turbo on top of it.... Any mileage is great mileage.
