OK, I broke it - Ford Truck Enthusiasts Forums
OK, I broke it
Old 12-20-2013, 07:40 PM
smallello's Avatar
smallello smallello is offline
smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.
OK, I broke it
I have Vintage Air AC and it has a capilary tube on the control panel. Well, I broke it off the switch. What does it do?
I never use the heat only the AC. Can it work without it or do I have to replace the switch it was connected to?
Old 12-20-2013, 07:45 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
The compressor won't cycle if that is broken. Those switches aren't cheap, tho. Take the old one to an A/C shop and they can surely match it. Or...
NAPA -- THERMOSTATIC SWITCH
Old 12-20-2013, 07:54 PM
smallello's Avatar
I was afraid of that. Thanks!
Old 12-21-2013, 01:47 PM
smallello's Avatar
Looks like I can replace the entire panel for less than just the switch.
http://www.summitracing.com/parts/vt...-shq/overview/
Old 12-21-2013, 02:32 PM
ALBUQ F-1's Avatar
postin' fool
Looks like they have other individual parts not listed, might be worth giving them a call.
Old 12-21-2013, 10:20 PM
smallello's Avatar
Yeah, I will give them a call on Monday.
Old 01-05-2014, 10:16 PM
smallello's Avatar
So I ended up replacing the whole controller.
The PO cut a hole in the dash for the stereo just under the cluster. I never really liked it there so I thought this would be a good time to move the AC controls to that spot.
I made a panel for the new controller so that it would cover the radio hole and hold the controller. I wanted the panel to be recessed so the the controller would sit flush in it. I used fleece and fiberglass resin to form it and painted it with a textured paint. It is a much better location for the controller.
Old 01-05-2014, 10:20 PM
topmoo's Avatar
topmoo topmoo is online now
topmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant future
What a great solution! It really looks good, nice work!
Old 01-05-2014, 10:25 PM
The Horvaths The Horvaths is offline
The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.
Job well done.
Old 01-06-2014, 12:03 AM
Bluey Zedoff's Avatar
Bluey Zedoff Bluey Zedoff is offline
Bluey Zedoff has a great reputation on FTE.Bluey Zedoff has a great reputation on FTE.Bluey Zedoff has a great reputation on FTE.Bluey Zedoff has a great reputation on FTE.Bluey Zedoff has a great reputation on FTE.Bluey Zedoff has a great reputation on FTE.
Looks a peach!
Old 01-06-2014, 12:24 AM
Chris 56 f6's Avatar
Chris 56 f6 Chris 56 f6 is offline
Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.Chris 56 f6 has a great reputation on FTE.
That my friend is a very nice fix.
Old 01-06-2014, 07:26 AM
Harrier's Avatar
Harrier Harrier is online now
Harrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud of
Wow great fix, that looks awesome.
Old 01-06-2014, 08:54 PM
smallello's Avatar
Thanks guys. Now I just have to get the console installed so I can get the stereo re-installed...
help wiring up push start button and ign switch isenegger Electrical Systems/Wiring 14 09-29-2015 09:16 PM
Vent door problems ALedbetter1 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 10-17-2014 10:41 AM
ac problems jaygotmilk 1997 - 2003 F150 7 08-26-2014 07:23 PM
installing toggle switch for fog lights, FordBoy2012 1997 - 2003 F150 5 12-05-2012 07:29 PM
AC QUESTION JJJRoberts 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-13-2012 10:21 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
