1978 - 1996 Big Bronco
How to 4x4?
Old 12-19-2013, 07:32 PM
blackhawk21's Avatar
blackhawk21
blackhawk21 is offline
How to 4x4?
Hey guys, long time since I posted here
So, since some sort of ****storm is about to fly into my area, wanted to throw the '84 into 4x4. The guy I bought it from said to
-Lock hubs (duh)
-Throw in neutral
-Select 2HI, 4HI, or 4LO
-Reverse
-Drive away
When I follow those steps, It seems like something is slipping. Both hubs were locked, and I followed those steps exactly.
What did I do wrong?
Thanks for the help.
Old 12-19-2013, 07:35 PM
blackhawk21
Oh, forgot
1984 Ford Bronco XLT
5.8L V8 351
3-Speed Auto
Old 12-19-2013, 09:17 PM
Conanski's Avatar
Conanski
Conanski is offline
Are you hearing grinding when 4hi or 4low is selected? If so the most common cause is a stripped hub but it could also be a t-case problem but it's pretty easy to narrow it down.
Old 12-19-2013, 09:49 PM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
Is this a push button 4x4?
1st off, reverse is not necessary unless coming OUT of 4 Low.
If it is you need to put it in park AND press the brake pedal to get it in 4 Low, it should slip right into 4 High.
Also if it is a push button the motor is your likely cause of failure.
Old 12-23-2013, 08:28 PM
86fsbronco's Avatar
86fsbronco
86fsbronco is offline
Dose it work in 4 low? Sometimes when you pull back on the t-case shifter to put it into 4 high it won't engage all the way its still in 2wd the front wheels won't have power to them the 4x4 light on the dash will light up and it will make a grinding noise hope this helps
jdw1
02-10-2019 09:41 PM
smittys5xs
03-27-2013 07:48 PM
LasVegas F250
03-04-2007 04:50 PM
rywegh
12-27-2004 02:33 PM
stonedmadd
1983 - 2012 Ranger & B-Series
02-26-2003 04:02 PM
Quick Reply: How to 4x4?
