Duraspark Harness Connectors DIY - Ford Truck Enthusiasts Forums
'80-'86 FAQs (Frequently Asked Questions) Calculators, specififications, automotive terms and acronyms.
Old 12-19-2013, 12:07 AM
KsCop's Avatar
KsCop KsCop is offline
KsCop is gaining momentum as a positive member of FTE.KsCop is gaining momentum as a positive member of FTE.
Just a quick FAQ. If you can't find a DS2 harness, and don't want to shell out the $$ for one from Painless, you can use their wiring diagram (free, online) and buy your own connectors. If you are like me, I needed a connector so I could get my gauges to work after my Carburetor / DUI Ignition Conversion. In any case; here is the info:
E-core coil connector,
Standard S-539 or NAPA/Echlin ICC1
Factory Canister Coil Connector,
Standard S-583 or NAPA/Echlin ICA102
Module 2 Wire connector (power),
Standard S-629
Module 4 Wire Connector (Control)
Standard S-698
Old 01-13-2014, 11:26 AM
monkey jason monkey jason is offline
monkey jason is starting off with a positive reputation.
does the duraspark coil take a different wire connector than the tfi connector? and how bad is it to just run the tfi coil? with duraspark ll distributor.
Old 01-17-2014, 12:37 PM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
I'll add to this. When hooking up DS2 into a 84 truck that had the TFI EEC4 carb. I found the 2 pin (red and white)connector of the 84's TFI harness is switched when you plugged in the DS2 plug!!
I found this out after rebuilding a wire harness for my 84 F250 300 I6. I plugged it in and verified connections, found those two are switched! Not sure if it was only this truck but something to look out for.
Old 01-17-2014, 12:41 PM
ctubutis's Avatar
ctubutis ctubutis is online now
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Yes, the red wire connects to the white wire, and the white wire connects to the red wire. I belive they have ALL been this way since the mid-70s when the system was introduced...
Old 01-17-2014, 05:20 PM
ArdWrknTrk ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
... the plug only fits that way, doesn't it?
I've heard about the wire colors reversed at the connector, but have never owned a mid '80's TFI truck, so IDK.
Old 01-17-2014, 11:30 PM
ctubutis's Avatar
Yes, the plug fits only one way, to only one mating connector.
Old 01-18-2014, 06:07 PM
Quote:
Interesting how Ford did that. Good to know as now I again will rewire that connector.... correctly. At least I found out before getting that harness installed!
Old 01-18-2014, 08:32 PM
pedant
You would know right away, since you would lose spark as soon as you let off the key.
Old 01-22-2014, 05:17 PM
1985tullyhowell 1985tullyhowell is offline
1985tullyhowell is gaining momentum as a positive member of FTE.
ok here is what I found with that so called reversed set up
it IS the RIGHT way red to white , white to red they just did that for some reason or another .
if you try to reverse it (red to red etc.) it will run full 12 volts and start at the resistor (7-9 volts)
it will run white to red etc. and right
they only plug in (factory like) ONE way that is how it is supposed to be
so yeah reverse it back to reversed colors
I haven't figured out why they did it that way either , even the diagrams are that way
some with one pole on the starter solenoid mine and like 1984 and newer
and some with 2 small poles on it, 1983 and older
Old 03-06-2014, 09:34 AM
pedant
Standard S-629
Standard S-698
Just an FYI (coming from another thread)
It was asked for these #'s and it doesn't seem there is a better place to make them easy to find.
Coil connector, NAPA EC238 (ICA102 doesn't show up in their search)
2 (3) wire connector, NAPA EC72
4 wire connector, NAPA EC127
Old 03-06-2014, 11:42 AM
Piston Honda's Avatar
Piston Honda Piston Honda is offline
Piston Honda is starting off with a positive reputation.
Here is the cheapest prices I found for module and ignition coil connectors
Module connectors
Ford Clips And Fasteners
They offer the coil connector too, but it is a ten pack
Coil horseshoe connector
Automotive Electrical Connector Pigtails, Terminals, Tools and More
With shipping costs it might be cheaper to buy everything from the second link or get the module connectors from Ford Clips And Fasteners and then get the horseshoe from Napa
Installed new starter solenoid and ...hmmm turbogus Electrical Systems/Wiring 2 07-15-2014 05:09 PM
Duraspark control module abyars111 1973 - 1979 F-100 & Larger F-Series Trucks 9 04-29-2013 04:09 PM
best starter relay replacement / upgrade ? triskadek Ford Inline Six, 200, 250, 4.9L / 300 11 09-26-2012 07:42 PM
Motorcraft 2150 Adjustments wyckedcombo17 1973 - 1979 F-100 & Larger F-Series Trucks 2 02-20-2011 11:55 AM
Duraspark coil connector? fmc400 Electrical Systems/Wiring 5 01-25-2008 05:27 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
