1951 F3 Project - Page 2 - Ford Truck Enthusiasts Forums
1951 F3 Project
Old 08-11-2014, 10:38 PM
sam03 sam03 is offline
sam03 is starting off with a positive reputation.
Cleaned out the garage and I'm working on getting the truck in the garage for the tear down. But with two complete flat tires with rusted out rims I'm looking for some cheap 8 lug rollers around me on Craigslist. Hopefully I can start painting the frame this week and get the brakes apart and start rebuilding them. Any advice on brake master cylinder? I'm going to keep the drum brakes but thought abt moving the master cylinder. Also brake line kit or bend my own?
Old 08-12-2014, 07:28 AM
pineconeford's Avatar
pineconeford pineconeford is offline
pineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to beholdpineconeford is a splendid one to behold
Hi Sam,
I did not find a pre-bent line kit anywhere for our size truck. Since the fronts are all the same you might get some pieces for an F-1, but the rears will have to be made by hand so might as well do it all.
Hope this helps, Tom
Old 08-12-2014, 04:33 PM
LMC has kits for an F2 I figured it would fit.
Old 08-21-2014, 12:42 PM
tractormanbill's Avatar
tractormanbill tractormanbill is offline
tractorman
tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.
10-4 on getting the title in your name!
In Texas I just got back from the DPS trying for title on my clean running and driving stock F-6 and found out someone had turned in an abandoned vehicle paper on it and in Texas it is not possible to get a title once this paper is filled with the state. You can on salvage titles and others but not on abandoned units.
I guess it is change frame if I want it or just part it out!
TractormanBill
Old 08-21-2014, 01:15 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Or go license it in another state than bring it back. Could that work Bill?
Old 08-21-2014, 01:32 PM
That's a shame surely there is some way to save it.
Old 08-21-2014, 02:09 PM
tractorman
It is a shame to put such a clean truck like this in the bone pile.
On the over the state line thought, when you came back to Texas I am pretty sure the serial # would pop up when they checked it as an out of state vehicle trying to get a Texas title.
You have to take the vehicle down to the inspection place and they go over it with a fine tooth comb.
TractormanBill
Old 08-21-2014, 04:14 PM
Sell it to a Canuck Bill. I hear they will buy anything. FoMoCo Moe would Shirley buy it.
Just don't call him Shirley.
Old 08-21-2014, 05:03 PM
jmadsen's Avatar
jmadsen jmadsen is offline
jmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to all
Looks like a nice f6 truck. Theres a guy in utah that will also buy just about anything. Bring it on up!
Old 08-22-2014, 10:59 AM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant future
I know a guy up in Washington who once found a crack in the frame right across the vin #. After welding up and cleaning the crack he licensed the truck with the serial # on the transmission, which he got from a rotted out titled truck. Seemed like a lot of work, but I heard he had a great truck for many years.
Old 08-26-2014, 09:24 PM
Picked of some tires and wheels on Craigslist. Hopefully I can get them mounted this week and finally get the truck in the garage.
Old 08-27-2014, 12:15 AM
frankcowan's Avatar
frankcowan frankcowan is offline
frankcowan is starting off with a positive reputation.
Florida is pretty picky about titles on old vehicles. I have purchased trucks from states that do not have titles on old trucks. And when I try to get a title in FL it is always different depending on who is at the DMV that day. If you are prepared with 'good' bill of sale and vin verification from law enforcement you can almost always get the title. There is also a company in Tampa that can help you through the process. pm if you need their contact info.
  #28
Old 09-03-2014, 10:23 AM
Finally got the truck in the garage this past weekend. I have one more wheel to put on but looks like on going to have to cut a lug nut and a socket that's was hammered on to a stud.
  #29
Old 10-20-2014, 02:58 PM
Finally had some time and got the last wheel and tire off. I starter cleaning up the frame and engine bay and priming for paint. Primed some of the inside of the cab. Pulled the transmission from the 226 and found out the ford had two different bell-housing that attached to the 226...And the bell-housing that came with the truck is from a v8 which doesn't work. So back to searching for another flathead part. I wish there was a local junk yard or garage where you could trade parts in for what you need.
  #30
Old 12-30-2014, 11:02 AM
Fire wall is gone the frame needs another coat and will be ready.
226 stripped of the trans.
The right plate for the truck bell housing.
I got the clutch kit in and now just have to find the right bolts to mate the bell housing to the trans.
Cab and Front End Mismatch tigerfan79 1948 - 1956 F1, F100 & Larger F-Series Trucks 32 01-05-2016 06:12 PM
Info Thread: MS Bonded Title process fslay Mississippi Chapter 3 10-27-2014 07:50 AM
Two trucks - One title westmoreland 1973 - 1979 F-100 & Larger F-Series Trucks 10 10-01-2013 05:31 PM
My title story bobj49f2 1948 - 1956 F1, F100 & Larger F-Series Trucks 27 09-29-2013 11:07 AM
Another bad title to vin (strange one) old broke prospector 1961 - 1966 F-100 & Larger F-Series Trucks 22 03-11-2013 07:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
