Combustion in fuel
Combustion in fuel
Hey guys,,, I'm messing with a 2008 6.4,, I have 230 psi lower compression in #8 than #6. I'm wanting to check if the injector is sealing the combustion chamber. Can you guys point me in the right direction. Should the schrader valve on the fuel cooler show pulses of exhaust if its the injector. Where do I test for combustion in the fuel?? Thanks guys
Most of you guys know what is in store for this truck huh.
Here are the symptoms.
Misfire on #1 cylinder,, not recurring,,, yet????
Cont/bal cyl #8 ,,,,, this is recurring
Misfire on #8,,,, not recurring
Runs fine most of the time,,, then it starts stumbling until the ignition is shut off n restarted.
Does that white sludge on the filter cap look like biofuel residue ?????
rideracelivemx7
19
02-24-2011 06:44 PM
strokin'_tatsch
17
03-23-2010 12:38 AM
Fordbronco69
21
09-20-2008 07:52 AM
