Just received my muffler delete for my 4" mbrp exhaust and was wondering if their was a easier way to break down the exhaust. I plan on using wd40 and a rubber mallet.
use a rust buster type of spray wherever you plan on separating the pipe. Let it soak then start on it. If you start from the back first, only disconnect the rubber hanger for the section you are working on so the others help hold it all in place for leverage.
