flat black paint
wally
From experience; I agree that Single Stage flat black is a real bugger to keep looking good.....I gave up on it and repainted 2 stage; the clear having some "dull" in it. Then I found that I could wash it and use spray wax on it and it turned out pretty good.....not flat/ not shiney and would stay clean appearing. If you go with Gloss Black; you'll be cleaning it forever as it shows dirt the worst.....other colors and finishes get just as dirty; they just show less. Bottom Line tho: it's your truck,,,,do what ya want!!
I just finished painting my '53 panel with Du pont Hot Rod black (HHM-6400). The paint is two part (paint plus hardener) single stage. It is not flat but a satin or semi-gloss. Yes, the paint is kinda a pain. If you mess up you can't feather it out and re-shoot the bad area, you have to re-shoot the entire panel. That said, the paint flows and covers great.
For cleaning, I use Meguiar's Quick Mist and Wipe Detailer. Get's rid of finger prints etc and works great.
I would not recommend true "flat" paint. I ran around with primer hot rods for many years in my younger days and the finish just doesn't hold up. The flat black will fade after a few days in the sun.
Depends on the look you're going for. For a traditional truck, a gloss in one of the original colors. For the darkside, yeah, satin black.
Pictures were all on my old computer that bit the dust and I lost 'em all. I did not have any probs with the 2 stage painting....but: spraying this stuff takes some care......what you spray is what you get....there is not cutting and buffing. Then I had it painted for the 3rd time as shown in my gallery. And then.............I sold it.....sob sob.
Ran across this stuff in one of the mags the other day, meant to order some up as I've got a '56 Vw bug sprayed with the hot rod flats black. It might work alright?
Rat Wax - Matte Paint Detailer - Rat Wax - Car Care Products for Rods & Kustoms
It was a quicky job done in the garage, mostly to put something on there that wasn't porous a the primer that was currently on there. Looks ok from about 25+ feet out, didn't spend a bunch of time on prep, we shot this and my buddies '64 Vw notchback the same day.
#28
#29
