broken down on the side of the road.....
so i was driving along & my 2000 f250 7.3 started to chug then died. I pulled over & it started right back up. I did some running around & was on my way home & it did it again only this time it would barely idle (same chugging). It died again & now it wont start. Turns over strong.....any quick ideas before i break the bank on a tow?
How cold is it there where you drive? Sounds like a fuel flow issue. Is there any chance the fuel is gelling? Unscrew the lid on the fuel filter and see if it's full. It should be pretty close to the top.
Are you around 1/4 tank by any chance?
Did you fill up recently? If so, are you certain you pumped diesel into the tank?
Just throwing out ideas...
Thanks for the input everyone. I replaced the valve cover gaskets/wiring harness about 1000 miles ago but I will double check that something weird didn't happen with pins. I had an extra CPS in the glove box and switched that out with no change (that was my initial thought). It was in the 50's today but we just broke out of a week long cold snap where it never got out of single digits. I'm around 1/4 tank and I mixed in a fuel additive to help with gelling and had no problems through 3/4's of a tank except for a bit of a drop in mpg. When it was chugging before it totally died I was thinking water in the fuel from the temp swings but I would have thought it would burn it off and blow it through the system and start after a few tries. Ill keep everyone posted and thanks again for the input!
How do I move this thread to the 7.3 forum?
You can hit the report button on your post to get a mod's attention. It it the exclamation point in the red circle on the upper right side of each post. Just type in your request in the report window.
However, I would just do what Hotpocket suggests -
Let them know what is wrong and what you have already tried. Good folks over there.
