2004 6.0 will not crank after filter change
Old 12-17-2013, 10:49 AM
jmfincher's Avatar
jmfincher
jmfincher is offline
I really need some help. I had a fuel leak at the fuel pressure regulator. Changed filters, used motorcraft, and the regulator and replace fuel/water seperater plug. Now it will not crank. The pump is working fine and filling up the filter. When I did get it cranked and the pedal to the floor nothing happened. Can't get the rpms up and all. Only about 1000. Ford place want $180 to diagnose the problem. So that means I'll have to pay a wrecker to get it there first. Any help will be appreciated.
Old 12-17-2013, 10:53 AM
dvldog13's Avatar
dvldog13
dvldog13 is offline
Slow to turn over or will not fire? have you checked the batteries? are they fully charged?
Old 12-17-2013, 11:12 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
Does the fuel pump buzz a few seconds after turning the key to on. Is there fuel in the upper filter bowl? If yes on both, I'd bull the filter caps and double check the o-rings and retorque.
Off the wall a bit but the small harness that goes under the regulator to the fan shroud could cause a no-start. If I understand right you replaced the regulator? Maybe the wire is pinched somewhere.
If you did the blue spring upgrade, did you have any parts left over?
Old 12-17-2013, 11:34 AM
jmfincher's Avatar
jmfincher
batteries good, just replaced them about 2 months ago
Old 12-17-2013, 11:37 AM
bbender85's Avatar
bbender85
bbender85 is offline
is it not cranking or not starting? i gather it IS cranking, but not starting.
Old 12-17-2013, 11:39 AM
jmfincher's Avatar
jmfincher
fuel pump does buzz and fills filter. Don't know what you mean by blue spring upgrade. But if you are talking about the regulator, then no there where not parts left over. I should mention that I have replace the filter 3 times and checked all orings.
Old 12-17-2013, 11:48 AM
jmfincher's Avatar
jmfincher
you are correct, turns over but will not start
Old 12-17-2013, 12:04 PM
Rusty Axlerod
Sorry, read your post again and see you mentioned pump working and filter check. Maybe a connector unplugged or got leaned on during the work. Fan speed sensor at the shroud, map sensor on intake tube. Also could check LPO system by pulling oil filter and pushing drain back valve in bottom of housing. Should fill up with oil in 10sec or less when cranking.
Here's a link to the no start checklist, something might ring a bell.
https://www.ford-trucks.com/forums/8...condition.html
Old 12-17-2013, 09:08 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Is there Air Bubbles in the Filter Housing
This is Most common with Filter change they suck alittle air
Old 12-18-2013, 09:35 AM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
This is why you cycle the key 6 times (from what I remember) then start when changing the fuel filters.
Old 12-18-2013, 09:42 AM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
Install a fuel pressure gauge and you can see when the pressure picks back up. It also helps rule out fuel problems in no-start cases.
Old 12-18-2013, 11:27 AM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
Won't crank, means starter is NOT engaging.
No start, means starter engages but engine won't fire.
It sounds like you got it running, pedal to floor rpms won't go above 1000.
You probably have air in lines, turn key on. but don't try to start. Then key off, back on again. Do this 3-6 times waiting 20 seconds while key on. This pushes air out of fuel lines.
If it still won't start and run well, you likely have installed filter, cap, regulator housing cover, hfcm plug improperly and o-ring isn't sealing properly letting air in.
Sent from my Sprint PC36100 using IB AutoGroup
Cityguy13
02-28-2016 07:19 PM
wigpro
Modular V10 (6.8l)
06-06-2015 09:27 AM
dgulledge
01-04-2015 09:09 PM
Mcrafty1
09-18-2013 11:38 PM
daddy23
07-22-2013 08:50 PM
Quick Reply: 2004 6.0 will not crank after filter change
