14 F250...I believe RSC issues = problems later for me
I've had my 2014 F250 for less than a month now. I'm having issues with what I now believe is the stability control. Issue is I coast through a turn that has a bump on it at approx 25-35mph, not fast or speeding at all, I get a pulse of the brakes. Why I believe it's a stability problem is this week I tried to have fun in the snow and I get the same deal when I try to slide the truck. Dealer really hasn't a clue yet, I'm taking it back for them to play with it this week. Once I get the issue resolved, my real issue is going to be I am going to lift the truck. I'll almost expect problems. Has anyone lifted a truck with stability control and not had issues? If you did how did you fix them? I know how to turn the system off with the dash button which isn't a long term fix. Looking for some input on someone who has lifted one.
Finally someone else with the same problem as me.
I have a 2012 F250, crew cab short bed, 6.2 truck and when ever I take a corner, that is slightly off angle, and catch a bit of bump I get the same brake pulse and even hear the brakes "grab". Occasionally I will get a traction control light as well but not every time.
Since yours is stock, and I've lifted mine, I can figure it's not the lift or tires that are causing the issue.
I've been to several dealers, and while I can duplicate the problem for them, no one has been able to figure out exactly why this is occurring. No codes are being thrown or stored.
We thought it might be steering position sensor being out of whack, so we recalibrated that, and still no fix. The latest dealer is contacting ford to see if there are any other suggestions from their end.
I would definitely like to keep in touch with you to see if either your dealer or mine can narrow this down.
And I will make this note, when I put the lift on, as I was backing out of the bay, I got a "Service Stabilitrac" message on the dash for about 2 seconds. It went away on its own and has never been back. There was no code stored when I took it to the dealer, and nothing appeared out of spec.
I'll see what I can find out tomorrow when I take the truck down. I don't want it back until it's fixed. It has done this since the day I brought it home. I have 1200 miles on it and almost 400 of those miles are trips to the dealer and back. I believe 5 star can tune out the stability stuff. If I have to do that after a lift kit I'm ok with that but not a new, bone stock truck.
I want to get this escalated up to your regional customer service managers so they can assist. Send me a PM with your full name, best daytime phone number, VIN, mileage, and preferred servicing dealership. I'll get this into their hands.
Crystal
Crystal,
Thanks for the help. I will PM you shortly with the info.
Nitemare
I did a little testing today. Drove the same road, same conditions, and same speeds. With the traction control and Stabilitrac on, there were several curves that the truck would nearly bring me to a stop on, and I would get the traction control light to flash. If I turned off the traction control (one pres of the dash switch) OR turn off the Stabilitrac (long press and hold of the dash switch) I would still have an issue, although not quite as bad. If I turned off BOTH traction control and Stabilitrac (one press on the dash switch, wait a few seconds, and then a press and hold of the dash switch) then I could drive the truck however I wanted and no feeling of the brakes engaging.
Maybe you can do the same and see if you have the same results.
Nitemare
It's been a while so time for an update. After many trips to the dealer (this was a few weeks ago...been quite busy) they finally accurately reproduced the problem. They checked it over and believed to have found the steering angle sensor was out of spec and replaced it. Problem still exists. They drove a few other trucks, same issue. The answer from the dealer is that it is characteristic of the vehicle. There is nothing broke so there is nothing the dealer can fix. I'll be down right honest, this issue is a disgrace. Characteristic of the vehicle or not myself and everyone else that has driven or rode in this truck say it's an issue that needs a fix. I've owned Fords since I started driving, pretty sure this is the last one.
you can hold the traction control button for 5 seconds to disable everything. It will become active again after i believe 35mph. It's annoying to have to do this everytime I get in and start the truck but it does pretty much eliminate the problem. I contacted a few tuner companies and they can make the traction control disable upon startup but not the stability. I do know everything is disabled in low range so my possible next move is to fool everything to think it's in low range. I don't know if the truck is smart enough to realize it's not in low. It's terrible to have to screw with a brand new truck.
Nitemere i feel you
But keep in mind rsc is federal mandated and ford tried to build a system to satisfy the requirement so its partly O's fault!
I can see several scenarios where the trucks rsc engage brakes on a corner could be very dangerous!! Lots of corners you can go around at 35mph but maybe not if 1-2 of the brakes engage!
DFWCabinetman
1999 to 2016 Super Duty
17
10-20-2014 06:24 AM
RM2738
6.4L Power Stroke Diesel
12-12-2011 07:58 AM
