Hi guys i have problem with my bronco 2 it has 45 psi fuel pressure
it is getting spark but its weak spark when i squirt gas in the throttle body
it wont fire up any help on this would be great thank you
Have you pulled the distributor cap and checked the carbon button in the center, and the rotor cap, also check for corrosion on the ends of the coil wire.
