1962 F100 Restomod
1962 F100 Restomod
I have just started working a project that really means alot to me. It is a 1962 F100 Uni-body pick up. I use to have a 61 that my stepfather gave me a long time ago. When my stepfather passed away my mother ended up moving.The truck had gotten left behind and then disappeared. My brother gave me this 62 in place of it so I am building it in memory of my stepfather.
Well I got more work done of it yesterday. It's a little cold out there today so I'm going to do more research of parts that I know I need so far. Here are a few pics of what I got done yesterday.
I took the seat, fuel tank, and mats out and this is what I found.
The steering column was kind of fun to take out but I got it.
I know they make the two floorboad panels but does anyone know if anyone makes the lower firewall panel?
Well I have figured out what engine I am putting in this thing and how I want to build it.
460
block
Stock crankshaft
ARP 350-6802 - ARP Crank Pulley Bolts
ARP 150-2501 - ARP Balancer Bolt Kits
ARP 255-5502 - ARP Main Stud Kits
Eagle H-Beam Connecting Rods 6605F3D
Milodon 31929 - Milodon Street and Strip Oil Pan Kits
Milodon Stainless Steel Oil Dipsticks 22035
Ford Racing M-6600-A460 - Ford Racing High-Volume Oil Pumps
Keith Black/KB Pistons KB137KTM-30 -
Keith Black KB Performance Piston and Ring Kits
Valve train
D0VE heads with larger valves, port job, chambers polished and port match
(330-ish/190-ish cfm flow @.600)
Intake valve size increased to 2.19
Exhaust valve size increased to 1.76
COMP Cams Xtreme Energy Cam and Lifter Kits K34-247-4
COMP Cams High Energy Die-Cast Aluminum Rocker Arms 17045-16
Lunati Pro Series Stud Girdles 91647
Crane Rocker Arm Guideplate Conversion Kits 52655-16
Air/Fuel
Weiand Stealth Intake Manifolds 8012
FAST EZ-EFI Self-Tuning Fuel Injection Systems 30227-KIT
460
block
Stock crankshaft
Valve train
Air/Fuel
OldSchoolRodz
07-02-2008 05:04 AM
Gaderene
02-26-2005 12:06 PM
