Water under the dash, rusted cowl or? - Ford Truck Enthusiasts Forums
Old 12-16-2013, 06:33 PM
cadunkle's Avatar
cadunkle cadunkle is offline
cadunkle is gaining momentum as a positive member of FTE.
Fairly new to me truck I noticed a couple days ago driving in heavy rain dripping water onto my feet. I've had several of these trucks and never had a leaker before, didn't think they were all that susceptible to cowl rot. Is this likely to be the cowl rotted out? Could plugged cowl drains on each side cause water intrusion? Rusted channel around windshield? Seemed to dump a bit inside when going around a highway offramp long right turn, so thinking pooling in cowl and maybe a hole in the right side. Fortunately our cowl panels are quick and easy to remove. Also heater box has a small piece cracked and missing a bit around the evap core. Doubt it's coming from there though as it's a fairly sheltered location.
I'll just have to pull the cowl and windshield trim and look, but curious if anyone else has had water leaking under the dash and found a particular problem area. Unfortunately it's too cold to do a hose test until we get a warm snap.
Old 12-16-2013, 07:11 PM
bruno2's Avatar
bruno2 bruno2 is offline
bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.
Maybe plugged , but quite possibly the windshield leaking too.
Old 12-16-2013, 07:27 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
The best way to test this is with a water hose. Run water down inside the cowl only and see if it leaks. If it doesn't after running it a little while, move up to the base of the windshield. Move back and forth on it, then move up each side, and then move along the top.
I had a floor leak on the little ranger pickup someone gave me, and I did a lot of messing around with the door seals and other stuff till I finally got the water hose out. After pulling the carpet back and drying the area out, I ran the water hose here and there and finally found the seam at the floor/kickpanel junction was leaking when I put water in the cowl. After tearing different pieces apart I found I could not access this area, so I dried it off good and put some roof sealer on the seam, not expecting much success from that, but believe or not it stopped the leak.
Old 12-17-2013, 05:44 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
The factory windshield seal on these have a tendency to let go. My old man's 84 was so bad I could push on it a little and see daylight. Had that also happen on my 86.
Old 12-17-2013, 12:33 PM
cadunkle's Avatar
I see water today coming in along the driver side A pillar. Possible windshield seal, I'll pull the trim inside and out to get a better look and see if it's bad seal or rust.
Old 12-17-2013, 02:42 PM
1986F150six 1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
Try gently, but firmly, pressing against the windshield from the inside and then the outside. On my son's 1984 F150, which was leaking as you have described, the windshield would actually move when doing the above. The seal had let go. This can become dangerous... imagine if the windshield lifted at speed!
Old 12-17-2013, 06:53 PM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
If it's coming down the pillar it is often the windshield seal, but be sure to check the caulking in the rain gutters and from there to the corner of the windshield as well.
Old 12-17-2013, 08:28 PM
bruno2's Avatar
Gary Lewis resealed his windshield with something called a "flowable silicone" from the parts store.
Old 12-22-2013, 07:01 PM
cadunkle's Avatar
Definitely windshield seal is leaking. Pulled the outside trim and could see a couple gaps between the windshield and the seal/goop. Whatever goop was used originally or to try to reseal later is dry and deforms/crumbles pretty easily. I used RTV on it this morning pushing it in as best I could and after rain tonight it's dry so far and no more drips below dash. Wasn't a heavy rain so time will tell if that's the only source. At some point I'll just have a glass shop pull the windshield and reseal it, I can't imagine that would be terribly expensive.
Old 12-22-2013, 08:26 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Getting a windshield out without breaking it can be tricky to do, might just go get another from the very beginning....
Old 12-23-2013, 08:21 AM
86fordtruck's Avatar
86fordtruck 86fordtruck is offline
86fordtruck has a good reputation on FTE.86fordtruck has a good reputation on FTE.86fordtruck has a good reputation on FTE.
I had a similar situation with El Guapo, but in my case, it was coming through cracked caulking in the cowl. Cause? Cracks in the firewall behind the clutch master cylinder. If you have an automatic, you shouldn't have that problem. It sounds like that may not be the source of your leaks, but I wanted to throw it out there for others who might read the thread and have manual transmission with hydraulic clutches. Good luck with the fix on yours.
Cleaned out the cowl on the 77 that's for sale bigredtruck 1973 - 1979 F-100 & Larger F-Series Trucks 4 06-28-2016 11:17 AM
Rust Inhibitors. Fancy name for either self etching primer and paint or just spray on bed liner? Cruiseomatic General Automotive Discussion 4 10-28-2015 11:45 AM
Interior water leak beartracks 1973 - 1979 F-100 & Larger F-Series Trucks 9 12-23-2014 01:56 PM
Cowl Water Leak TexasGuy001 1987 - 1996 F150 & Larger F-Series Trucks 19 05-03-2011 03:51 AM
99 Expedition Windshield or Cowl Leak hgufrin 1997-2006 Expedition & Navigator 9 03-16-2010 10:24 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
