You know, there are so many things that can cause pinging. The truth is, the timing on our 3.0's has been set to a level that puts it at the very edge of pinging even under perfect circumstances. Where this leaves us is having a good engine that Ford has tried to tweak for max performance and minimal emissions.
I believe that with good TLC and proper maintenance, the Vulcan will run forever. Its just more important to keep em tuned than on some other engines. The positive is, that this annoying ping kind of alerts us that we need to perform some routine maintenance where other engines, also needing the same maintenance, don't let the driver know until it becomes a huge issue. Now I know this is not the intention of the designers, its just a more positive spin on tghe old pinging problem.
If you think about it, the pinging has probably made most people (at least on the forum) perform maintenance that they would hav e not performed if the pinging never occured).
I posted before that I added ethanol as an additive for a few tanks to stop pinging, it worked and I have now ran 3 tanks with straight 87 (no ethanol) from Amoco and have no pinging. I believe that the ethanol clkeaned my fuel system anbd probably got rid of some carbon buildup. My guess is that I will have to do it again every few months but I have no problem with that.
Anyway, maybe we should all hold hands and sing coom-by-ya and thank the Ford engineers for our little "maintenance reminder alarms".
