I am second guessing myself on choice of oil for the "winter". - Ford Truck Enthusiasts Forums
North Carolina Chapter Join Chapter, Leader:ncheavymetal
Old 12-16-2013, 09:52 AM
Mr James's Avatar
Mr James Mr James is offline
Mr James is starting off with a positive reputation.
I live and work in the Winston Salem, NC area. We are new to the state, having moved here from San Antonio, TX. I purchased the truck upon moving here; it has 1 previous owner and he is local to Winston Salem.
I originally posted this a few weeks ago: http://www.ford-trucks.com/forums/12...-carolina.html
I ended up using 10w-30 Mobil oil in my truck. I don't pull anything with it and I thought I would be driving up to Michigan a few times this winter with it, but I am not. I am not used to the winters in this area and have no idea what to expect as far as temp ranges. Should I change the oil back to 15w-40? I dont want to use synthetic yet.
Old 12-16-2013, 01:13 PM
ncheavymetal's Avatar
ncheavymetal ncheavymetal is offline
NC Chapter Czar
ncheavymetal is a splendid one to beholdncheavymetal is a splendid one to beholdncheavymetal is a splendid one to beholdncheavymetal is a splendid one to beholdncheavymetal is a splendid one to beholdncheavymetal is a splendid one to beholdncheavymetal is a splendid one to behold
I'd wait for fuzzy to chime in he is the diesel guy around here.
My non-diesel opinion would be to put what the manual suggests. It just doesn't get all that cold around here. A little colder where you are then here in the triangle but not much. Nothing like up north/mid-west.
For the Winston area the average low in January is 25f. The average High in July is 87f.
I'm not a fan of full synthetic regardless of engine or climate.
Old 12-16-2013, 01:59 PM
Mr James's Avatar
Yeah, the ford manual says 30F and above, use 15w-40 and 30F and below use 10w-30. We seem to ride the line here in Winston. Was 27F this morning. I used to live in northern Minnesota and it was -20's and -30's regularly Dec - Feb... I didnt have a diesel and I mostly drove my snowmobile to work anyways!!
Old 12-17-2013, 09:04 AM
fuzzy1626's Avatar
fuzzy1626 fuzzy1626 is online now
fuzzy1626 is gaining momentum as a positive member of FTE.fuzzy1626 is gaining momentum as a positive member of FTE.
I leave 15w-40 in my "old school diesel"(with 190,000 on the clock) year-round. The 10w-30 will be better for start ups. The problem is the really warm days we get this time of the year. Fri 67, Sat 70. I think my son used the Motorcraft synthetic blend in his 6.0 .
Had Hub go bad in Winston/Salem, NC kev03 Excursion - King of SUVs 9 12-07-2014 10:10 AM
New Guy From Winston-Salem WhySoSerious New Member Introductions 1 10-06-2014 11:21 AM
FTE Int member Short Visit to USA ftrk66 1961 - 1966 F-100 & Larger F-Series Trucks 8 03-09-2014 05:23 PM
At Wits End db9397 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-25-2014 11:39 AM
15w-40 or 15w-30 in North Carolina?? Mr James 6.0L Power Stroke Diesel 16 11-17-2013 06:35 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
