OIl TEMP ON THE RISE - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 12-16-2013, 07:46 AM
MYWEIGH's Avatar
MYWEIGH MYWEIGH is offline
MYWEIGH is starting off with a positive reputation.
I have a 08 F350 SD with 110,000 miles. I change the motor oil between 3000 & 3500 miles. I'm running KEM tunes with a K&S tuner. Driving yesterday I noticed the oil temp slightly unstable and ranging from 203 - 213 deg. For the past several years this truck never went over 203 deg. Is this a sign the oil cooler is going bad? and if so what's involved in replacing the cooler. Thanks in advance.
Old 12-16-2013, 03:13 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
At the same time...what is your water temps? Perhaps it is the thermostats.
Old 12-16-2013, 04:35 PM
MYWEIGH's Avatar
I don't monitor my water temp in the h&s, but the guage sits just under 12:00 - it's the best I can come up with
Old 12-16-2013, 04:37 PM
senix's Avatar
monitor the delta for water and oil and then report back.
Old 12-16-2013, 05:59 PM
MYWEIGH's Avatar
I will work on it - thanks
Old 12-16-2013, 09:05 PM
GSchretter's Avatar
GSchretter GSchretter is offline
GSchretter is gaining momentum as a positive member of FTE.
Are you running a coolant filer?
When was you last flush?
Oil cooler could be clogging or just has some nasties you need to flush out.
Old 12-17-2013, 05:59 PM
MYWEIGH's Avatar
This is what I saw -
water: oil:
194 205
204 209
197 207
192 201
195 201
192 207
still noticed that the oil temp is a lot more unstable than usual
Old 12-17-2013, 06:03 PM
senix's Avatar
your delta seems ok.
I suggest a coolant flush. When was the last one completed? Have the nitrites ever been tested?
Old 12-17-2013, 06:04 PM
MYWEIGH's Avatar
no, I'm not running any coolant cooler - can you flush the oil filter? I'm real religious on changing the oil and use Kendall 20w50 and have on all my trucks from my 87, 93, 02, 06, 08 Fords & 1-Dodge (thought I would try one out) and 3 medium duty International Trucks DT466
Old 12-17-2013, 06:08 PM
MYWEIGH's Avatar
I've never have done a flush on the coolant system and have not run any tests either.
how does the coolant flush effect the oil temp. I understand you keep the engine cool will keep all fluids cool but I thought there is a oil cooler? am I incorrect in my thinking?
Old 12-17-2013, 06:11 PM
senix's Avatar
There is an oil cooler in the valley of the motor. Coolant runs through it.
Checking the chemical make up of the coolant helps with corrosion protection as well. Since you have just over 100K it is over due.
Old 12-17-2013, 06:22 PM
UGA33's Avatar
UGA33 UGA33 is online now
UGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud of
You ran 20w50 in your 06? Was it a 6.0?
Old 12-17-2013, 06:36 PM
MYWEIGH's Avatar
so I'll check the properties of the coolant - is there possible damage already to the oil cooler - or will the flush clean it up?
Old 12-17-2013, 06:38 PM
MYWEIGH's Avatar
yes it was a 2006 w/ the 06 engine sold it with 76000 miles - sold it - hauled the trailers great - sucked in the sand - fell for the 08 and haven't look back since - great truck. has a minor issue here and there but don't they all.
Old 12-17-2013, 06:39 PM
senix's Avatar
I am thinking just do the flush. Your delta's are still fine.
I don't think any long term damage at this time.
200-203F coolant temp needs addressing draboo 6.0L Power Stroke Diesel 3 10-03-2016 09:47 PM
Normal Temp Ranges and upgrades to coolers. Otto396 1999 - 2003 7.3L Power Stroke Diesel 28 05-03-2016 09:41 AM
transmission overcooling? RedneckTrucker 6.7L Power Stroke Diesel 32 03-09-2016 09:34 AM
ECT VS EOT Temp OUTLAWSSAA 6.0L Power Stroke Diesel 5 05-18-2015 09:44 AM
Engine Oil Temp v Coolant Temp Bigtruc 1999 - 2003 7.3L Power Stroke Diesel 20 12-26-2013 10:24 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
