OIl TEMP ON THE RISE
There is a procedure to do the flush, very indepth. I would suggest you consult your local dealer and see what they would charge.
Ford gold coolant is what it takes and that is what I would consider using again.
some speculation about converting over to ELC but I have not really heard very many have.
well I did the flush - didn't really notice a whole lot of dirt / debris coming out. used the ford gold and diluted 50/50 w/ distilled water as recommended. now my water & oil are closer in delta but - my water goes from 193 - 205 and my oil is from 197 - 210 doesn't really stay at one reading real long - even on cruise control 78 mph. I really thought I remember the oil steady @ 203. any thoughts?
if you mean the fluctuations between the 2 temps - yes they would both fluctuate. as far as flat ground - here in So. Florida the only time it's not flat is at a land fill. went to Miami 90+ miles and they would change consistently. outside temp 65* and rainy the whole trip. I don't if this this information is what you're asking. I just know my truck and something is definitely different. what is the temp range on the oil and water? unable to really time - changes fairly quick - seconds ? thanks again
you say sucked the sand, what does that mean?
thanks
05 f250 6 inch lift
07-18-2019 10:32 PM
FORD352V8
02-27-2005 12:07 PM
