Chuck's Trucks 48-50 Ford F-1 Build
Love the pictures, and awesome job by the way. You do a very meticulous job, and if you do all the engineering on your frame work I know how much work this can be.
I have a few of these vintage trucks all COE's needing restoration, but would not have the funds or time it would take to do.So I may just sell them.If this is your day job Its a great feeling getting paid to do something you must certainly love.
Getting a stroked flathead with a 4-barrel & C-4. Couldn't talk the customer into a blower but that's OK. Easy to maintain and drive for the customer
The body is going on the TCI frame. Much quicker to have the pros engineer the suspension, and way better than the Volare front clip going away which looks welded to the stock frame with a harbor freight flux mig! The old build wasn't dangerous at least, but certainly not up to the standards we want to put out. Chris
Continuation of the build.
Added pics of the cab. The whole header was rusted through and lab metal filling up the rust Cut it all out and head to stretch a new flange and weld it in. Needs a floor and firewall as it's pretty cut up Doors and hood are off at the body shop
http://s919.photobucket.com/user/chu...Project%202013
The replacement one we have is a bit pitted inside but fixable The outside flange was only just starting to rot through at the roof and most of the major rust was contained to behind where the rubber seal was so for that I sheared some sheet metal to size
I used a Brake to make the "Z" Used a shrinker to make the flange curve to match a cab I had in the shop
Alb.. Actually this is Chris I'm working for Chuck on this build among others I've been putting the links up for whomever wants to watch here on FTE I have a couple metal working tools and enjoy working with them. Shear, finger brake, shrinker / stretcher, couple hand tools.
I have a couple OT projects as well as early Ford trucks going at the moment.
Patched
