Alternator conversion?
Old 12-14-2013, 06:01 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
This is what I came up with for a mount. It's based roughly on this link
Y-Block.Info
I'm not altogether happy with it. It will work but the alternator is mounted upside down. That means jacking up the truck to change belt/s (I'm set up to run two) or R&R an alt. I'm building up an old truck to have maintenance and repairs simple and this isn't as simple as I'd like. Show me your alt mounts. Thanks
Old 12-16-2013, 08:09 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is online now
Looking for a simple reliable Y Block myself. What else have you done. I'm still running a Generator
Old 12-16-2013, 09:41 AM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
My mods are sparse. I'm building a travel rig and don't want to be stranded in Bumsquat Egypt due to a part being hard to get. I'll have a spare alt, starter, w/pump and a spare fan belt. The liklihood of 3 fan belts breaking before I return to civilization are slim to none
Old 12-16-2013, 09:52 AM
bjmayberry2
I'm with ya! I wanna travel in mine as well but there's nothing like walking into a parts place and asking for ANYTHING on a 50s vehicle. Many times they have what you need but unless you know the part number or run across an old timer at the counter you'll probably leave empty handed.
Old 12-16-2013, 02:17 PM
schoo's Avatar
schoo
schoo is offline
here's my alt cost $60 and some used parts
Old 12-16-2013, 02:20 PM
schoo's Avatar
schoo
schoo is offline
another view
Old 12-16-2013, 02:54 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
Schoo, that isn't a whole bunch different, but enough so that doing alt R&R will be simpler. Don't have to line shtuff up. Looks good!
Old 12-18-2013, 05:50 AM
The Horvaths's Avatar
The Horvaths
The Horvaths is offline
Mummert sells a robust (cast aluminum) alternator mounting bracket. I don't have pictures yet.
Old 12-18-2013, 08:54 AM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
I've seen that. Robust is a good way to put it. But I'm looking to get ideas to make something. Buying things takes all the fun outa the build
Old 12-18-2013, 05:37 PM
The Horvaths
Amen to that! Are you up to casting aluminum? I've done everything but that (so far). I've helped to cast aluminum. I've played with glass blowing, blacksmithing, silversmithing, lapidary, faceting, you name it. I'm toying with the idea of setting up a small foundry. That's a couple of years down the road. Meanwhile, I still weld, plasma cut, smelt silver and palladium, and even start an occasional coal forge in my suburban neighborhood. Some of the neighbors actually think it's cool. Most probably hate me.
Their loss, I guess.
Old 12-18-2013, 06:30 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
TH, you're a bit more ambitious than I am. I just have a simple shop. I do a little welding, but only enough to get me in trouble
Lynnmcmahan
07-05-2019 06:21 AM
ghart
08-21-2016 10:45 AM
quincyj34
02-23-2015 10:40 PM
RIKIL
13
07-02-2012 10:01 PM
OregonJen
1947 and Older Ford Trucks
02-12-2012 11:36 AM
Quick Reply: Alternator conversion?
