Alternator conversion? - Ford Truck Enthusiasts Forums
Old 12-14-2013, 07:01 PM
vntgtrk's Avatar
vntgtrk vntgtrk is offline
vntgtrk is starting off with a positive reputation.
This is what I came up with for a mount. It's based roughly on this link
Y-Block.Info
I'm not altogether happy with it. It will work but the alternator is mounted upside down. That means jacking up the truck to change belt/s (I'm set up to run two) or R&R an alt. I'm building up an old truck to have maintenance and repairs simple and this isn't as simple as I'd like. Show me your alt mounts. Thanks
Old 12-16-2013, 09:09 AM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is offline
bjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud of
Looking for a simple reliable Y Block myself. What else have you done. I'm still running a Generator
Old 12-16-2013, 10:41 AM
vntgtrk's Avatar
Quote:
My mods are sparse. I'm building a travel rig and don't want to be stranded in Bumsquat Egypt due to a part being hard to get. I'll have a spare alt, starter, w/pump and a spare fan belt. The liklihood of 3 fan belts breaking before I return to civilization are slim to none
Old 12-16-2013, 10:52 AM
I'm with ya! I wanna travel in mine as well but there's nothing like walking into a parts place and asking for ANYTHING on a 50s vehicle. Many times they have what you need but unless you know the part number or run across an old timer at the counter you'll probably leave empty handed.
Old 12-16-2013, 03:17 PM
schoo's Avatar
schoo schoo is offline
schoo has a great reputation on FTE.schoo has a great reputation on FTE.schoo has a great reputation on FTE.schoo has a great reputation on FTE.schoo has a great reputation on FTE.
here's my alt cost $60 and some used parts
Old 12-16-2013, 03:20 PM
schoo's Avatar
another view
Old 12-16-2013, 03:54 PM
vntgtrk's Avatar
Schoo, that isn't a whole bunch different, but enough so that doing alt R&R will be simpler. Don't have to line shtuff up. Looks good!
Old 12-18-2013, 06:50 AM
The Horvaths The Horvaths is offline
The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.
Mummert sells a robust (cast aluminum) alternator mounting bracket. I don't have pictures yet.
Old 12-18-2013, 09:54 AM
vntgtrk's Avatar
Quote:
I've seen that. Robust is a good way to put it. But I'm looking to get ideas to make something. Buying things takes all the fun outa the build
Old 12-18-2013, 06:37 PM
Quote:
Amen to that! Are you up to casting aluminum? I've done everything but that (so far). I've helped to cast aluminum. I've played with glass blowing, blacksmithing, silversmithing, lapidary, faceting, you name it. I'm toying with the idea of setting up a small foundry. That's a couple of years down the road. Meanwhile, I still weld, plasma cut, smelt silver and palladium, and even start an occasional coal forge in my suburban neighborhood. Some of the neighbors actually think it's cool. Most probably hate me.
Their loss, I guess.
Old 12-18-2013, 07:30 PM
vntgtrk's Avatar
TH, you're a bit more ambitious than I am. I just have a simple shop. I do a little welding, but only enough to get me in trouble
Finally have a truck again!! nnero 1987 - 1996 F150 & Larger F-Series Trucks 21 01-13-2017 09:59 PM
HOLY SCORE, BATMAN!! vntgtrk 1957 - 1960 F100 & Larger F-Series Trucks 49 03-16-2014 06:42 PM
Dual Snorkel Air Cleaner vntgtrk 1957 - 1960 F100 & Larger F-Series Trucks 10 02-16-2014 02:05 PM
Hit a deer! nnero 2009 - 2014 F150 50 01-28-2014 01:25 PM
Help with O/D trans ID vntgtrk 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 11-16-2012 05:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
