2010 6.4L DPF Issues - Page 2 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 12-17-2013, 08:44 PM
aquaman aquaman is offline
aquaman is gaining momentum as a positive member of FTE.aquaman is gaining momentum as a positive member of FTE.
A sigh of relief!!!
Old 12-17-2013, 08:45 PM
Scornwell Scornwell is offline
Scornwell is starting off with a positive reputation.
Great to hear. Thanks for reporting back.
Old 12-27-2013, 07:13 PM
CobraR6 CobraR6 is offline
CobraR6 is starting off with a positive reputation.
Well it looks as if my issues with the truck are not 100% solved. In about 550 miles the truck has regened 4 times. It's taking about 30-34 miles to let it complete the regen process. It seems as though the average time between them is 120-150 miles. Sometimes a lot less than that.
The majority of these miles were highway miles. The biggest issue is the amount of oil I am gaining on my dipstick. As of now I am well over an inch above the max oil level when inserting the dip stick fully. When using the method where you don't insert the dip stick fully, I am approximately 1/4-3/8" above the max oil level. This is after only 550 miles!
I get that it will gain some oil over an oil change , but I am only 550 miles into having the truck back and I've gained this much. I can only imagine what it would be if I let it go 5,000 or even 7,500 miles between oil changes.
Old 12-27-2013, 07:34 PM
Are you running biodiesel? Our trucks should not be using anything more than B5. Biodiesel is *bad* for the DPF
Old 12-27-2013, 07:35 PM
In PA they have a requirement of at least 2% bio. The stations where we fuel use B2 (2% bio).
Old 12-28-2013, 01:10 AM
Any chance you can try different brand of fuel? From what I've read, frequent regens and excessive oil dilution are symptoms of biodiesel. Low cetane is another problem. I once used some Valero to save a few cents/gallon and regretted it with a bunch of regens on that tank.
Old 12-28-2013, 06:15 AM
We do use a Cetane improver that was recommended by Ford. As for trying a different brand of fuel, around here it all comes from the same place. The only difference between brands is the name and the bio percentage. 2% is the lowest you can get in PA. Looks like I'll be contacting the dealer next week.
Old 12-28-2013, 07:21 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I'd be checking those injectors
Old 12-28-2013, 09:37 AM
wp6529 wp6529 is offline
wp6529 has a good reputation on FTE.wp6529 has a good reputation on FTE.
Quote:
Absolutely, however given the history of the DPF apparently soaking in diesel after not getting "light off" in regen, I'm inclined to think it will take a while of normal regens for it to actually recover.
As for fuel dilution, on my truck I have found I only get any notable fuel dilution (over 0.5%) if I interrupt regens. As long as I pay attention to when the turck is in regen (Scangauge II) and drive around until it completes I don't have a fuel dilution issue.
If you change the oil, ensuring it's at the proper level, drive a month or two making sure you don't interrupt any regens and you still have fuel dilution issues then I'd insist on injector inspection.
Old 01-25-2014, 08:00 PM
jlrFordFan jlrFordFan is offline
jlrFordFan is starting off with a positive reputation.
Hey Cobra,
Giving this thread a bump, hoping to have an update.
Old 01-26-2014, 06:29 PM
Sorry for not updating earlier. This was mainly due to there not being much to update on. The truck still regens every 150 miles and the dip stick keeps growing with oil. The dealer said this is normal and the truck will gain oil to some extent. So basically we will wait for the oil change to see how much oil it has gained. I do not know the correlation between how high over full equals x quarts of oil. We cut the oil change back to 5000 miles instead of 7500. I guess we will just wait and see.
In the mean time we are checking into aftermarket solutions for getting the emissions stuff off the truck all together. The warranty is up this year and hopefully as soon as it's done we will throw something on it. I am leaning towards the spartan kit now, but am looking into having the filter gutted and reprogrammed. This gives it a stock appearance but gets rid of the emissions, I am also told this is cheaper than the spartan kit too.
I will update when the oil change rolls around and let you guys know where I'm at.
Thanks again for the help.
High Altitude Areas Regeneration Issues while Towing? Homebrewer29 6.7L Power Stroke Diesel 18 09-05-2016 03:26 PM
Intermittent loss of power question JHG88F350 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 09-05-2016 10:50 AM
MY SUMMER TRIP 9400 MILES OF FUN StanleyZ 6.7L Power Stroke Diesel 15 08-29-2015 12:06 PM
Oil Issues NateMack06 Modular V8 (4.6L, 5.4L) 1 04-23-2015 06:52 AM
Sitting at the dealer/ check engine light boulderbronco 6.4L Power Stroke Diesel 5 04-04-2011 08:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
